External wastegate on your GTX manifold
    Originally posted by protégébob View Post
    if it's only a drag car you could always make a small sump/reservoir below the turbo and use an electric pump to scavenge the oil back to the pan. There's a turbo vette at my local track that runs something similar to that (except that he uses a single stage dry sump pump to scavenge back to the pan)
    I had a crazy idea about something like that also.
    Boosted 1990 4WD
      Originally posted by wht95scort View Post
      Its nice but will make the turbo sit too low to have a proper oil return line.
      don't u make an adapter for the gtx mani's? I was just curious cause i want to mate up a gt30r to the gtx or gtr mani
        External wastegate & CS downpipe repaired
        well, i've taken the external system to a totally different welder this time around & found a good few things needing to be repaired, 2 cracked welds on the corksport downpipe were ground & retig'd & the wastegate tube was welded with mallable mild filler to decrease strain & promote some movement during expansion.
        the flange was repaired & the tube was also reattached to the CS system.
        all in all the system is once again 150% solid & not going to leak for a good long time.
        Examine your CS downpipes for cracks if you've put them through extensive beatings theres a good chance it will crack around the welds.
        a few pictures & a comparison shot next to a CS-DP/VF10 hybrid
          wow my vj20 is small
            Looks wonderful dude !
            Nice job, and well done
            Posted this on the Dutch 323BG club, since we have received three corksport downpipes three weeks ago, so I can show them a pic now if they want an external wastegate.
              tell them i have a mandrel U bend & another flange for making the pipe going up from the CS Downpipe.
              BTW, i just ran out & tested this.... it does fit with unaltered stock radiator brackets.... if you slot the holes you can increase your saftey-zone even more.
              2 thumbs up
                looks better than when I saw it in the parking lot a month or two ago! I'm almost itching to turbo my 323, but I have to keep reminding myself that this is supposed to be an ECONOMY car, not a FAST car....
                --sarge
                  meh, they put an ECONOMY motor in a car that should be fast
                    I think that you got a bad downpipe or something cause Ive never had any issues with it fitting correctly or welds breaking.
                    Boosted 1990 4WD
                      originally it was a crapshoot downpipe. i even contacted corksport about it. after heat cycles & all of the changes made to it tho. its honstly better then a new one id say
                        Sorry to revive a 4 year old thread...but is that DP a 3" with 2" Waste pipe?
                          1.5" waste pipe 2.5" DP (corksport made these for awhile. mine was just modified)
                            Thanks for the reply...that 2.5" looks like 3" ...well you cant tell the difference in a picture...
                            Thanks again for the info...
