Ok guys. I need some help. I just did the BPT swap into a 2 gen pro. I have all the wiring completed except for these ones because i just don't know what they are for. So here are some pics. Thanks.
Name The Pic
number 3 (yellow ) is the radiator fan switch/sender, its not for the ECU, thats the green one that you cirledbefore
the other sender at the front of the head (not pictured), its black,with brown strip wire ,its the dash sender, not used by the ECU, but help full so you no whats going on
Fan sender is required for the fans to work, or you can just earth the cable
i'll wire them up in the morning. The ecu i have only takes one temp sensor so as you said i'll have to ground the fan temp sensor so the fans works. Thanks guysLast edited by reddragonmazda; 09-23-2007, 12:40 AM.97 Mazda Protege GT
BEFOREAFTER
What aftermarket ecu are you using that doesnt have a feature to control the IAC?Beater=/= Sleeper
Originally posted by kozzman555kitty, you are a hilarious womanOriginally posted by HopelessCowthere is one thing i dunno what is that call,a thing look like a gun, u press the button and stick to the metal and it makes firework, do i need that thing?and what s the philip head screw drivers?
