Safc wiring diagram
    Safc wiring diagram
    hey guys i searched and searched and im not having any luck finding a wiring diagram for an apexi safc in a 1990 protege lx. if anybody has one that would be awesome thanks
    Originally posted by escort underground site
    How to :: HOW TO: Install SAFC Into 2nd Gen GT GT Harness
    SAFC Power (Red) White/Red on harness (1B)
    SAFC Ground (Black and Brown) Anywhere On Body
    SAFC RPM (Green) Yellow/Blue on harness (2E)
    SAFC Air Flow (White in, Yellow out) Red on harness (2O) GT-X Harness Knock Sensor (Purple) 2J/Red-Yellow
    Link to the acuall thread:
    proboards25.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, proboards25.com has it all. We hope you find what you are searching for!
      this should be a sticky.
      5 boosted bp cars,why...
        Done. I will double check with the admin's here to make sure its fine. It should be fine though, its not copywriten or anything.
          Originally posted by Turpro View Post
          Has anyone used this way to hook theirs up? I'm about to hook mine up but want to make sure its correct before I start cliping wires.
            Bump. Not sure if this is correct info. There's still the throttle wire and with my 4 wire conversion I'm guessing that's where I tap for that.
              Hey, here is the wiring for a 92-93 SOHC
              Red Wire - Power
              Green Wire - RPM Signal
              Gray Wire - Throttle Signal
              Brown Wire - Ground
              Black Wire - Ground
              Yellow Wire - Air Flow Signal Output
              White Wire - Air Flow Signal Input
              Blue Wire - used for 300ZX
              ______________________________
              Red Wire - 12v Source
              Green Wire - 2E
              Gray Wire - 2L
              Brown Wire - 2C(Closer to ECU)
              Black Wire - 2C(1cm Away From Black Wire)
              Yellow Wire - 2O(Wire Coming From ECU)
              White Wire - 2O(Wire Coming From Harness)
              Blue Wire - 2N(Reads 02 Voltage)
              Green Wire - 2E - White
              Gray Wire - 2L - Light Green with White Stripe
              Brown Wire - 2C - Black with Light Green Stripe
              Black Wire - Same but 1cm Further Away
              Yellow Wire - 2O - Red
              White Wire - 2O - Red
              The Red Wire on the S-AFC harness can go to 1B which is a power wire.
              If you don't have the service manual this is how the connecters are arranged:
              2Y 2W 2U 2S 2Q 2O 2M 2K 2I 2G 2E 2C 2A
              2Z 2X 2V 2T 2R 2P 2N 2L 2J 2H 2F 2D 2B
              1U 1S 1Q 1O 1M 1K 1I 1G 1E 1C 1A
              1V 1T 1R 1P 1N 1L 1J 1H 1F 1D 1B
              Plug 1 is closer to the firewall while plug 2 is closer to the center console.
              DISCLAIMER: In no way am I responsible for your screw up. If you have any doubts, you should consult your genuine Mazda shop manual or have your Mazda dealer photocopy the appropriate pages from the wiring manual. Once wired up, you will need to tune your car. I can offer tips but again, it is your a--. This device will either help your car or blow your engine up, what you do will result in one of those outcomes. Choose wisely.
              And Turpro owes me 2 hrs of sleep... I couldn't get back to sleep!!!
              Mexican: "You wanna race for titles?"
              Mormon: "lol, no, I don't want your car."
                Thanks Clayton
                I didn't relize ppl left their cell phones on next to their head lol. I guess I'm crazy that I turn mine off at night. Sorry for the wake up call.
                  Thanks Clayton
                  Yeah I have the work phone because I am on call incase someone has an electrical issue, and then I use my phone as my alarm clock... sometimes it wakes me up early when People on the East coast forget I live on the West Coast!!!
                    Well technically I did have an electrical issue lol. Yea I figured it was work related. Thanks again for the info
                      i followed this too!! everything works i just need to know what to set the sensors on the safc to for a sohc motor with stock maf
                        well heres a intresting should the throttle voltage be reading 4.8 at idle and 0.2 wot?? i checked the throttle % screen and it says 0 at closed throttle and 100% at wot, but it wont read anything but 0 or 100 it wont show anything inbetween... could this be a bad TPS??
                          I have a 93 protege with the 1.8 Dohc automatic transmission ecu with the three plug harness...I'm trying to install safc2 and need the wiring diagrams and pinouts or what ever info u have to help...thanks
