junkyard gems/oem upgrades
    ya thats a thaught, most of our cng cars around here are in the city from national fuel so its worth a look i guess, they are using honda civics now too , i wonder what those would be...i know those are direct fit but probably would need resistors...
    92 protege lx-
    94 protege lx-
      ^only the older civic's had low ohm's which would require resistors........ however its always safe to double check
        Originally posted by bpt323 View Post
        how well do they sit in the BP head???
        They fit like they were made for the car. They're the same length as GTR injectors (3" long) and the insulated tips are the same diameter.
          i been told some people in pr used these injectors, and its from any v8 ford....^have you got the running with them yet?
          323 log-http://www.clubprotege.com/forum/showthread.php?t=44611
            No, still collecting parts to complete the engine build. Planning on taking some other top-colors to see what they flow.
              they dont' run CNG here in the states..... maybe the taxi cab's but those things run forever.
              mail me a set
              There are fleet vehicles used by city's that have this. Phoenix has/had some. Police, Fire, taxi, etc. They get sold at auctions, end up as taxi's or to the general public, then in junkyards around here.
              FS Forged H beam rods
              awaiting test fit
              Aluminum CAS/Distributor caps
              BP oil jet eliminators
              EV14 fuel rail spacers
              More stuff coming soon.......
                KIA BP SERPENTINE PULLEYS.
                I had some issues with the V belt jumping off my bpt when i hit the rev limiter. I now have a KIA BP which has 2 serpentine belts and I never seen that problem again. If you make this upgrade make sure to get the right accessories to go with them (alt, p.s.p. ect.)
                Also if you already have the Kia Bp or pulleys, The 88-92 MAZDA MX-6 alternator works with those pulleys.
                And if the alternator plug gets damaged, most nissans use the same plug.
                sigpicBACK TO SQUARE 1
                  a 94-97 miata Alt uses the Serp belt and works for this too. I believe its 80 or 90 amps compared to the stock 60 or 65.. It's been a while since I looked at mine.
                  -Steve
                  94' Protege < Worklog<SOLD!
                  VF10 powered!
                  262 Whp & 257 Wtq
                  13.1@107
                  '02 Suzuki Bandit 600s
                    upgrading your alternator to anything more then stock is a huge improvement all around
                      I don't know if this has been posted yet, but I found out that there's a difference between the gt rear bar and the escort wagon rear bars. The wagon ones are solid, while the gt's and I think all other rear bars are hollow.
                      My family has lots of bg's!
                      1992 Mazda 323: Race car
                        ^ old information most of the "ancient members" would only know
                        for a good information repost
                          I just did the 90A and I agree with this.
                            wich one did you use? and wich one is the easiest one to use?
                            94 pro base model, all synthetic fluids, s/r struts, front & rear ebay upper strut bars,front & rear tie bar, ZX2 1" front swaybar, EGT 21mm rear sway bar, custom delrin endlinks front & rear, custom delrin rear swaybar mount bushings, EBC front blanks & redstuff pads, CS ss brake lines & dot 4 fluid, big drum brakes in rear (from ZX2, free parts), 2.25 custom exaust w/magnaflo oval muffler, 4-wire o2 sensor, custom ram-air, 4-wire BP tb, MSD super conducter plug wires, MSD Blaster SS coil, NGK iridiums,OEM weighted shift knob, ebay short shifter, bronzoil bushings, CS ss clutch line, custom air splitter, mx-3 recaro drivers seat, EGT foglight switch, 35w 5000k hi/lo hid's
                            soon:
                            lightened flywheel & clutch; in garage,
                            Miata Daisy's; after new tires
                              I used the MX-3 V6 90A
                              You need to change both bolts the one on the bottom goes in the other way and needs to be longer (this is imo a better design)
                              I beleive it needs to be 130mm long
                              Bolt on top needs to be changed as well as the alternator isn't threaded, so you'll need a bolt/nut combo.
                              Pulley needs to be swapped over as well as the washer from the old 65A.
                              it takes about 20mins to do all of that.
                                were you able to use the same belt?
                                I ended up having to go with a longer one. I think it was once size longer then stock..
