Junkyard oem upgrades
    This will be a compiled list of all the oem upgrades you can get from the junkyard for you 90-94 protege/323 and 91-96 escort gt/lx-e and tracer lts.
    Add all your knowledge here:
    Originally posted by ryan1 View Post
    3rd gen escort front subrframe
    link to the subframe post =
    mx-3 v6 steering rack(quicker ratio)
    zx-2 front swaybar (25mm)
    i guess i would be to tell people size/benofits of the mod to, if its a direct bolt on or any modding too make work, and even a link of pics or talk about the mod/upgrade.
    thanks
    Originally posted by Mazda_Powered View Post
    The MX-3 LCA and TTLs are 30mm wider
    For the front you just need to grab the MX-3 LCAs and cut off the droplink bracket to expose the endlink holes.
    As for the rear, you need both rear TTLs, you can run your current swaybar, but you'll need to get some heim joints, talk to Ryan BPT323 about those.
    It's a fairly straight forward swap, i'm not 100% sure if i'll end up doing this to my 323 since i dont have any TTL hardware anymore (damn parents).
    JACK.
    mx-3 v6 rear lower tie bar.
    Originally posted by Clean 4WD View Post
    1988-89 rx-7 alternator from a gxl 90amp. bolts up to the pro with little hassle and swap the pulley from the stock alt.. a quick upgrade from 60 to 90amps.. thats my .02$ worth..
    the 90-92 mx3 recaro seats count? since people do upgrade their seats to a racing/bucket style for autoxing for more in seat grip?
    Also someone mentioned we can use 3rd gen protege upper strut mount assemblies front/rear so we can use 3rd gen springs/coilover sleeves.
    Then 3rd gen protege shifters are supposed to be 15-20% shoter throws compared to our stockers.
    BG BP automatic rads are supposed to be thicker as well for better cooling.
    2nd gen BP/kia upper 1/2 of the intake manifold is 1" taller and has a different runner flow/style.
    Kia BP axles are a simple axle swap if you've changed to the MSP LSD.
    From what I'VE seen, 93+ MX-3 GSs come with a 2.25" catback exhaust system. At least all the ones i've ever seen (fit mx-3s, 323s)
    ALSO. VAF adapter comes STOCK on ALL Merkur XR4Ti cars. Takes a bit to get at them tho.
    Not sure if the 2.3 Mustangs do either, the SVO's would.
    Hope this has helped or confused
    JACK.
    Originally posted by bpt323 View Post
    FS alternators are all 80 amps.
    RX7 AFM's are an upgrade
    the FS 2.0 alternator only needs the pulley changed & it bolts right in place... id suggest a larger ring terminal tho for the power feed.
