how much $$ is a map sensor ....
    and who makes good turbo manifolds for a bp with external wastegate???
    besides cork sport,,
      what kind of map sensor?
      you can get a 3bar gm at atpturbo.com
        You can get a GM 3 bar MAP sensor at any local parts store. I don't remember the part # off hand, but there normally $60 or so. I think you might have to go custom for a manifold.
          What kind of ECU do you run where you're using a MAP sensor?
          Also, I don't know of anyone who makes a manifold for the FWD BP with an external WG. You could drill yours and put a ext gate on it.
            bp 10 ... but the map is for .. safc2....
            so i got the head off 4 and 3 are ****ed .... the porcelon got smashed on to the piston and ****ed the bottom of the head ... scored the cylendor wall ...
              gm 3bar map
              http://www.atpturbo.com/Merchant2/me...egory_Code=BCS
              Connector plug for GM 3 bar MAP sensor
