Vote for December ROTM
    Vote here for your December 2007 ROTM
    Good luck to everyone.
    And the nominees are:
    masterbanter
    redfox
    Hadoken
    Suzuka323
    40
    masterbanter
    22.50%
    9
    redfox
    60.00%
    24
    Hadoken
    7.50%
    3
    Suzuka323
    10.00%
    4
    Vote head.
      Being different FTW!!!!!
        voted
        sigpicSLICK PROTEGE
          voted
            Redfox is pulling away!
            Bump for more votes.
              This one was the hardest to decide on.
              I Do not own a Mazda anymore!
                <- showing the 323 love!
                  voted!
                  My baby 93' Protege Lx--R.I.P
                  New Baby 94' Protege Lx Black
                  91' Miata - SOLD
                  93' Protege LX new Project (no rust)!
                  Mods: Protege:
                  Engine: Fully built with wiseco 9:1 +1mm ceramic coated tops and molly skirts, M-tuned H beams, ACL Race rod and thrust bearings with King Mains, Arp Mains ,rod and head studs,3 lbs lightend crank, Everything is ballanced, spec stage 3 clutch,lightend flywheel, RX7 Afm, Fidanza Adj. cam gears, timing,Cut intake manifold from BPT323, exintake cam swap,full port and polished head 1mm stainless oversize valves, vf12/vj20Turbo, 3" custom full exhaust w/external wastegate,3" E-Cut, Eclipse crushed BOV , Fmic, Aem Urgo wideband, Autometer boost gauge, Magnaflo Muffler,batt relocated to trunk, slight wire tuck with engine bay fuse box under dash Bp26 ecu
                  Suspension: Energy Suspension rear trailing arms,Es Front Sway bar endlinks,Zx2 Front Sway Bar,El Sport w/bilstein mono tube struts and don't know what springs, Suspension Tequniques Rear Sway bar with Es endlinks,mx3 rear lower tie bar. corksport SS brakelines and clutch line.
                  Exterior: Adler Racing 16"s ,Mx6 Front lip,EGT Glass Sunroof,Edm Headlight & corners EGT side skirts,Gt Led wing, Led interior 3rd brake light
                  Audio: few things polk momo 6.5 components, VW Monsoon Front Componants with monsoon amp,alpine head unit
                    Voted!!
                    Boosted 1990 4WD
                      voted
                      '95 Ford Escort LX, GTX block .40 over, wiseco 9.1 pistons, gtr rods, gtx head, MS1, 550 inj. T3/T4 .57 Trim, DSM BOV, WALBRO 255 FP, civic half rad, MSP LSD, stage 3 kyclutch, ebay short shifter, mx-3 rear tie bar, AEM wideband....SHE IS ALIVE
                      '88 Mazda Gtx AWD B6T engine Ported head, VJ-11, EL prototype chipped ECU, Blitz SBC-iD electronic boost controller, Full HKS exhaust, Centerforce dual friction clutch & more
                        voted all are very nice!!!!
                        sigpic gtx swap,pacesetter cat back exhaust,civic short shifter,both front and rear upper strut tower bars,high flow cat,,mx-3 lower tie bar,mx-3 front seats,zxtuner poly motor mount inserts,manual seat belt conversion,mx-3 lether shift boot,
                        come to mazdasnw.com if you live in the northwest
                          voted....
                          R.I.P 93 Mazda 1.8 Turbo
                          now BP26(GTX) on a 91mazda323 381whp @18psi with microtech lt8..
                          91 mazda 323 v6 klde
                            voted.
                              Voted! I havent been here in a while since I sold my proto to oldskoolricer(danny). Steve (turboproto) made me vote...lol
                              (sold!)
                              1994 Mazda Protege/Familia 4dr Gtx motor, Sparco intercooler w/custom piping, hks blow off, mandrel bend 2.5"exhaust, gtx front and rear bumpers, jdm headlights, jdm led wing, jdm gtx grill, jdm strut bar
