Results 1 to 12 of 12
Thread: Please Help Solve a Turn Signals Mystery
  1. #1
    Registered User
    Join Date
    May 2007
    Location
    Vermont
    Posts
    4
    Feedback Score
    0
    Question Please Help Solve a Turn Signals Mystery
    Good Evening!
    Hope you all had a wonderful Thanksgiving. My daughter treated us with one of her rare visits, driving her 1998 Protege the six hours from college. She just got back to college and called home with a baffling mystery in which the turn signals are 'not working' and neither I nor the repair manual can make any sense. Hopefully you (the experts) can...
    Asked her if any of the lights at the four corners worked from the stalk switch; answer was no. Asked if the four-way hazard flashers worked; this is where it got weird. The answer was, they work fine, but only if one holds down the button all the way. On releasing the button, the hazard flashers simply don't stay on.
    Does this behaviour mean anything to anyone? Seems like wiring and bulbs are OK because each bulb will light and flash on/off with the hazard button held in. I'm about to have her go over the fuses, replace any relays in the circuit... something more?
    Thanks in advance!
    Cheers
    Rob in Vermont
  2. #2
    Registered User
    Join Date
    Oct 2003
    Location
    Miami, Florida & Put your loca
    Posts
    1,728
    Feedback Score
    0
    The first thing I can think of is a problem at that very switch that keeps the lights on only while being held in. I can't be sure and it's just a thought.
  3. #3
    Registered User
    Join Date
    May 2007
    Location
    Vermont
    Posts
    4
    Feedback Score
    0
    Thanks for replying Barry.
    Does this mean that the directional signals are somehow wired through (and dependent on) the four-way flasher switch?
    I worry about her taking this to some local 'mechanic' who will charge her for a few hours of his own education, only to tell her that the parts aren't available.
  4. #4
    Registered User
    Join Date
    Oct 2003
    Location
    Posts
    1,728
    Feedback Score
    0
    Quote Originally Posted by SAABMaven View Post
    My name isn't Barry . Anyway, with experience working on cars, electrical problems are very difficult. Without much experience with cars it's even worse. You may not have much of a choice but to take it to a mechanic. What you have to keep from doing is going to a regular mechanic. Find some place that says they specialize in electrical problems. Once again, asking friends & family about someone who has become a trusted mechanic is the best route, if available.
  5. #5
    Registered User
    Join Date
    May 2007
    Location
    Vermont
    Posts
    4
    Feedback Score
    0
    Thumbs up Thanks !!! May have been weather related...
    About 50km from her destination, normal functioning abruptly and inexplicably returned.
    Not to sweep this one under the carpet, but we had a wet and balmy week in Vermont for Thanksgiving. Then, in one night, temperatures plummeted to about ten below freezing, trapping moisture whereever it had condensed.
    I'm going to research this more, to see if there is some relay or other bit that I can proactively replace. If there are any ideas out there, please let me know.
    Cheers
    Rob
    PS I'd like to keep this car going. As a rallyist who has raced SAABs, I have a high degree of confidence that I can make the Protege do what I want it to do; especially on a snowy day. I say this of few cars today...
  6. #6
    Registered User
    Join Date
    Oct 2003
    Location
    Posts
    1,728
    Feedback Score
    0
    The Protege is a very, very reliable car. The engines are long lasting in the same league as Toyotas and Hondas. Other areas of the car aren't but the engines are.
  7. #7
    Former 4WD owner almighty4wd's Avatar
    Join Date
    Apr 2004
    Location
    Bozeman, MT
    Posts
    2,347
    Feedback Score
    10 (100%)
    To say something about the turns:
    There is an orange wire on the flasher box. That is the hazard wire. It "shorts" both left and right turns at once. The left is a red wire, the right is a green wire.
    If you have to hold the hazard in, then there may be a short in the switch, since it's only a springed toggle. If the turns don't work at all, I'd say a fuse. But since the hazards are acting up, I'm inclined to say the flasher box. It's large, black with a yellow male connector to a clear female, 8 wires.
    If the fuse is good, swap out the flasher relay. If that doesn't fix it (even though it fixed itself) it may be a switch issue. The moisture and freezing could affect it from shorting out a connection.
    Since the car drove and warmed up on her trip and possibly dried out, I'd believe it to be moisture is the primary cause. Let us know if it happens again!
    No car! I soldz it. Now I have a truck. I like it, but apparently it has a hard time keeping up with a slightly modified 4WD protege with half the hp. Neat.
  8. #8
    Registered User gybe's Avatar
    Join Date
    Sep 2007
    Location
    Pannonia, Slovenia
    Posts
    281
    Feedback Score
    0
    If the problem was moisture then inspect it a little closer because the problem can pop out at any time in future. Check for the isolation on every turn light on the car - take it off and see if it's wet. If the relay is having trouble will moisture then check where's the leak. Maybe the whole firewall is a bit clogged and water can easily find its way to cockpit.
    As for the flasher relay goes, as almighty4wd stated. But take into notice that the flasher can vary in color. I have a grey one but it says 'TURNING SIGNALS' on it or something like that. If you have remote power locks and car alarm that indicates with turning signals there should be at least some fuses at the flasher relay.
    Garage: Mazda Protege 1995, Z5 engine, MTX, P/S, no A/C, no ABS.
    PM me if you need: comprehensive Autodata information; Mazda's 2nd generation workshop manual; Mazda's Z5 overhaul workshop manual.
  9. #9
    Registered User
    Join Date
    Oct 2003
    Location
    Posts
    1,728
    Feedback Score
    0
    Quote Originally Posted by gybe View Post
    You did mean insulation instead of isolation, right?
  10. #10
    Join Date
    Sep 2007
    Location
    Pannonia, Slovenia
    Posts
    281
    Feedback Score
    0
    Quote Originally Posted by mannydingo View Post
    Sorry, INSULATION, yes. I am not a native speaker so mistakes are not excluded!
  11. #11
    Registered User
    Join Date
    Oct 2003
    Location
    Posts
    1,728
    Feedback Score
    0
    That's ok. As long as you don't feel isolated here my Transdanubian forum friend.
  12. #12
    Registered User Lord Blackfair's Avatar
    Join Date
    Mar 2016
    Location
    Lancaster,PA
    Posts
    4
    Feedback Score
    0
    I am almost having the same problem on my 97 Protege, My 4 ways wont work. Directionals do. I changed hazard switch and flasher relay. and the hazards still don't work. the fuse for hazards is good.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Help me Fix my Turn Signals.
    By Caitaru in forum Exterior/Interior - BJ Chassis
    Last Post: 11-10-2009, 03:04 PM
  2. Headlights go off when turn signals on?
    By lakota in forum General Discussion - BHA Chassis
    Last Post: 11-01-2008, 05:57 PM
  3. JDM headlights and turn signals
    By DJ_PaRaNoIsE in forum Exterior/Interior - BG Chassis
    Last Post: 12-04-2005, 10:49 PM
  4. no more turn signals...what did I miss
    By sk8er0i in forum General Discussion - BJ Chassis
    Last Post: 09-08-2005, 01:32 PM
  5. '96 turn signals
    By Boricua in forum Exterior/Interior - BHA Chassis
    Last Post: 04-15-2004, 02:17 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
