Heat doesn't work at idle?
    I'm trying to figure out the best way to troubleshoot this problem, but my 323's heat won't blow warm until I've been driving for a while. It won't stay warm at idle, but will blows warm again when revving it up. I changed the thermostat a couple of years ago. What should I be looking at as a culprit?
    Check your heater core. I would suspect ( as mine was) it is not flowing very well. I ended up getting some radiator flush, ran that in there for about a day and went back and back flushed the heater core with my garden hose. Heat works great now!
    Roads? Where we are going we don't need roads...
      Mine blows warm after a few mins of idling, but the upper rad hose is cold until you hold the idle up. i couldn't get my thermo to open until i held the idle up for a minute or so. its odd.
      Zero
      Young hearts be free tonight, time is on your side.
      Time is on your side.
        i'm thinking the waterpump isnt all that efficient @ low engine speeds , mine does the same with new rad/ heater core / thermostat..... or the damn pump is failing ...slowly
