So I've been reading about the failures of the small nose crankshaft that supposedly came in the '91 Escort GT as well as the '90-'91 B6 Miata and the '94 BP Miata. This link covers the details of the problem: http://miata.net/garage/crankshaft.html
There are some good pics of failed crankshafts here: http://www.miataclub.org/orlando/94crank/
I have a '91 Escort GT and I'm in the middle of putting a GTX turbo on it so this wasn't something I was happy to hear about. However, the miata article has this pic of the crank bolt for the small nose crank:
And this is the bolt on the miata big nose crank:
You can see the big nose crank bolt has a much larger shoulder. My bolt looks like the big nose bolt:
Can anyone familiar with this confirm that I have the large nose crank? I don't have calipers to measure it, but the size of the shoulder on the bolt looks like the large nose crank bolt and just using a ruler it looks like it's about the 1.455" the larger bolt is (the smaller bolt is 1.128"). I 'll be taking the timing belt pulley off next and then I should be able to measure the crank, but I might not be able to do that till next weekend so I was hoping someone could tell by the bolt. It certainly looks like the big nose crank bolt, but those pics are from the miata. Thanks!
