Results 1 to 12 of 12
Thread: Best way to strip paint off of bumper??
  1. #1
    Registered User TiKi's Avatar
    Join Date
    May 2004
    Location
    South FL
    Posts
    94
    Feedback Score
    0
    Just wondering what would be the best way to strip paint off of our plastic bumpers without damaging it ?? My bumper cover is looking horrible , I'd say a 1/4 of the paint has flaked off. I don't know which chemicals would eat through the plastic. Also what would be the best to remove laquer from the headlights? I have some laquer thinner but again dunno if it would damage it.
    94 LX
  2. #2
    Registered User progt91's Avatar
    Join Date
    Jun 2006
    Location
    Oshawa On Canada
    Posts
    2,428
    Feedback Score
    2 (100%)
    they sell paint stripper for plastic parts, you sould be able to get it at any paint supplier place
  3. #3
    Eating Honda's Daily j.sher350's Avatar
    Join Date
    Dec 2007
    Location
    Alexandria, MN
    Posts
    508
    Feedback Score
    2 (100%)
    if u have a DA sander (orbital) ...sand it all off. gotta sand it before you repaint it anyways.or u could always hand sand it w/ 80 grit paper. it'll take a lil bit to hand sand but you will like the results when you put new paint on...same w/ the DA sander
    as far as ur headlights. personally i would use anything to get the **** off.. and then buff the headlights. if you have that mothers ball deally doo. or any kind of car wax...you can buff the headlights back to clear....thats if they end up hazing over. but ur best bet is to prolly use an automotive laquer thinner
    92 Pro - Daily Beater and project- current frankenstein
  4. #4
    Registered User viper_707's Avatar
    Join Date
    Mar 2004
    Location
    kitchener, ont
    Posts
    919
    Feedback Score
    2 (100%)
    dont take 80 to a plastic peice unless your gonna repair it. it will just cause u more headaches than u wish to deal with. You can find a good paint stripper for plastic. then before u paint it use a good plastic prep paste a a medium sctratch pad. then wash it really good with soap and water. do a final wash with a alchol type cleaner and spry a good coat of a plastic adhesion primer before paint.
  5. #5
    Join Date
    Dec 2007
    Location
    Alexandria, MN
    Posts
    508
    Feedback Score
    2 (100%)
    yeh then the stripper soaks into the plastic's pores and you cant get it all out. either sand blast it or use like 320 grit paper on a da sander. (80 is for metal...*brain fart*)
    no mater what you do...the plastic has to get sanded some how or use a scotch brite pad n scuff it up. paint has to bite in some way or another.
  6. #6
    Join Date
    Mar 2004
    Location
    kitchener, ont
    Posts
    919
    Feedback Score
    2 (100%)
    the stripper doesnt soak in if u use a proper plastic parts stripper
  7. #7
    Registered User gybe's Avatar
    Join Date
    Sep 2007
    Location
    Pannonia, Slovenia
    Posts
    281
    Feedback Score
    0
    Quote Originally Posted by TiKi View Post
    Start with hands or knife. Just make a tiny bit, then scrape it off with a powerwasher. I powerwashed my bumpers once and now I have got white spots on a red bumper.
    I really need to repaint this one.
    Garage: Mazda Protege 1995, Z5 engine, MTX, P/S, no A/C, no ABS.
    PM me if you need: comprehensive Autodata information; Mazda's 2nd generation workshop manual; Mazda's Z5 overhaul workshop manual.
  8. #8
    Join Date
    Sep 2007
    Location
    Pannonia, Slovenia
    Posts
    281
    Feedback Score
    0
    Tiki, about the unwanted paint stains removal... you can use a product called 'M600'. It really isn't a name (Sikkens makes them too), it's a type. It's a lot like nitro or lava for lacquers, but it is not that aggressive, does not ruin glass or make a foggy appearance. It is actually just a very harsh degreaser which is used when prepping a part right before the paintjob. Just go and ask for something like it - Sikkens is premium stuff, but everything else should be fine too. Remember that M600 will not wipe off the paint already coated with varnish and dried... It's a very neat stuff when you **** something up.
  9. #9
    Join Date
    Dec 2007
    Location
    Alexandria, MN
    Posts
    508
    Feedback Score
    2 (100%)
    sikkens is junk. worst paint manufacturer ever. PPG is the way to go. I do autobody...i know what im talkin bout when i say the paint stripper will soak into the plastic pores. sandblast it or sand it. its gonna be way easier over all. the paint doesnt need to be completely stripped off, just get all the nasty **** off and get the majority of the rest off. get the clear coat and start into the basecoat. that'll be good enough. get it blown off. degrease it, prime it, sand it, prime it again, sand it and start ur 3 coats of base. clear it a couple times then wet sand the bitch...if wanted. shouldnt take ya to long to do it. a couple or 3 hrs.
  10. #10
    Join Date
    Sep 2007
    Location
    Pannonia, Slovenia
    Posts
    281
    Feedback Score
    0
    I wouldn't say it's junk. First you have to admit that you live in USA which can mean that you can get junk from Sikkens as we can also get American junk which is actually pretty decent stuff in America but when it is sold in Europe it is not.
    Also another thing worth mentioning is where you live and use these product. Paints can be pain in the ass and it is really crucial that you use paints that are suitable for your climates. My friend's father is a bodywork expert too and he has used Sikkens for 30 years now and has never regret it. It really depends on the style and what kind of stuff you get.
    It's like if you like cocoa chocolate or regular chocolate.
  11. #11
    Join Date
    Dec 2007
    Location
    Alexandria, MN
    Posts
    508
    Feedback Score
    2 (100%)
    yeah i do hafta agree with you there. my personal experiences with sikkens hasnt been to good though.
    and everyone has their own personal ways of doin stuff to. so if it works for ya...then hell yeah.
  12. #12
    Heritage Restoration Skuce's Avatar
    Join Date
    Apr 2005
    Location
    Paris Ontario Canada
    Posts
    1,726
    Feedback Score
    18 (100%)
    Soda Blasting.
    Will take off paint and not damage any of the substrate.
    Drew
    '95 EGT 1.8
    T
    '93 ELX 1.9 SC
    '91 ELX 1.9
Thread Information
Users Browsing this Thread
Similar Threads
  1. New X for the strip...
    By Shades in forum Wheels and Tires
    Last Post: 05-15-2008, 02:11 PM
  2. how to paint a non-colured plastic bumper?
    By tiletsio323 in forum Exterior/Interior - BG Chassis
    Last Post: 02-27-2007, 12:55 PM
  3. day at the strip
    By escortkid in forum Racing Stories
    Last Post: 08-27-2006, 09:02 PM
  4. I'm gonna strip
    By worldhazard in forum General Discussion - BG Chassis
    Last Post: 07-08-2005, 10:49 AM
  5. At the strip
    By OCD-SPEED in forum Photo/Video Gallery
    Last Post: 04-04-2004, 03:47 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
