Abbreviations and jargon defined
    Stickied
    MBSP- main bearing support plate(you have to luv mazda for putting them in a mazda bp )
    Some common abbreviation and acronym meanings that will hopefully get you started on a google search for more info. Feel free to add your favorites or correct any errors
    afm = air flow meter
    atx = automatic transmission
    b6 = 1.6 liter sohc inline four cylinder engine
    b8 = 1.8 liter sohc inline four cylinder engine
    bov = blow off valve
    bp = 1.8 liter dohc inline four cylinder engine
    cp = Club Protege
    cs = Corksport
    dohc = dual overhead cam
    ecu = engine control unit
    egt = escort GT
    fsm = factory service manual
    fmic = front mounted intercooler
    hla = hydraulic lash adjuster
    isc = idle speed controller
    itb = individual throttle bodies
    klze = 2.5l v6
    lca - lower control arm
    maf = mass air flow
    ms / ms2 = megasquirt
    mtx = manual transmission
    sohc = single overhead cam
    ss = stainless steel
    tdc = top dead center
    tps = throttle position sensor
    tmic = top mounted intercooler
    ttl = twin trapezoidal link
    vaf = volume air flow
    wtf = what the (four letter word starting with f)
    vics = variable inertia charging system (in the intake manifold)
    zx2 = escort zx2
    2003 Protege5
    1990 Protege LX (sold)
    1990 Protege DX (sold)
    1992 626 (sold)
    Common abbreviations and jargon on Club Protege: http://www.wihandyman.com/forum/showthread.php?t=34116
      bp- 1.8l dohc
      b8- 1.8l sohc
      b6- 1.6l sohc
      klze- you got me homer....
      bg- first gen chasis code
      omgwtfroflbbq- this is obvious
      siihp- stick it in her pooper
      AN/GAU-8a = traffic control unit
      lca= lower control arm
      isc?
      bp-ze?
      im hoping maybe the original post will be edited to contain the working list as its updated?
      egt= escort gt
      zx2= other escort moderatley newer(i think)<- may require sh*t talking, and correction
      Next!
        dilligaf = does it look like i give a **** LOL
        Check out the Pics
        http://www.wihandyman.com/forum/vbpi...?do=view&g=228
        Mazda's Rule Honda's Drool
          its the 2 door coupe version offered from 1998 thru 2003
          in 2003 it was discontinued they replaced it with the Fukas *yes thats spelled the way it is*
          in no way shape or form is the fukas like the escorts
          Check out the Pics
            Edited. I will keep editing. Sorry about taking your glory cojsl. When I merged and edited this thread it put me as the top person. It's all good though. Props to you
              turpro- doesn't bother me at all, thanks for cleaning it up I can edit again too!
              2003 Protege5
              1992 626 (sold)
                lol, tried to slip one by huh? I respect that! http://tech.military.com/equipment/v...mm-cannon.html
                2003 Protege5
                1992 626 (sold)
                  klze--DOHC 2.5l v6
                    since I have a second...
                    KL-DE = USDM DOHC 2.5 V6 (Probe/MX-6)
                    KL-ZE = JDM High Compression DOHC 2.5 V6 (some fancy 4 door sedan)
                    K8 = DOHC 1.8 V6 (MX-3)
                    http://videos.streetfire.net/video/M...-run_18851.htm
                      Courtesy of MD323:
                      BP= 1.8L DOHC motor
                      BG= chassis code for the 1990-1994 protege/323 as well as those goofy escort guys and those mx-3's who are also bg's but not.
                      BH= chassis code for the 2nd generation protege
                      2003 Protege5
                      1992 626 (sold)
                        I have a few to add:
                        STS = short throw shifter
                        CAI = cold air intake
                        SRI = short ram intake
                        BPT = BP turbo (BP-26)
                        BPD = GTR engine (BPC8)
                        P/S = power steering
                        C/C = cruise control
                        A/C = air conditioning
                        IDK = I don't know
                        IMO = in my opinion
                        IIRC = if I remember correctly
                        TTT = to the top
                          Also, the chassis codes and the corresponding years are all right in front of you on the forum main page:
                          1st Generation Mazda Protege / Familia (1990-1994) - BG
                          2nd Generation Mazda Protege / Familia (1995-1998) - BHA
                          3rd Generation Mazda Protege / Familia (1999-2003) - BJ
                          ETC...
                          And something everyone should have: http://www.protegefaq.net/
                            SRT-4 = CAN NEVA LOSE!
                            I just had to...
                              what the hell are these abbreviatons? and anything else of that nature?
                              FTW?
                              FTL?
                              Boosted 1990 4WD
