the vj20 just wont be enough. I am not 100% decided yet but i think im just going to sell my vj20, exhaust manifold, 3" exhaust, and injectors and just work on building my t3/t4 setup...
REASON: well a couple, If started to disassemble the pro and it makes me VERY happy to see minimal rust. Ive kinda decided ill strip the bay to nothing clean it, and spray it probably a gray color (the exterior to follow). meanwhile my father in law has talked me into rebuilding my already top end refreshed motor. It has kinda put me into a do it once right instead of 2 times just to get it done... not to mention the extra money flushed down the drain to bolt my vj20 setup on is not to exciting.
also a guy i work with just picked up an 05 evo. the car is mint, like 5k on the clock, the guy he bought it from was some rich dude with no extra time and every time he got it out he cleaned it before he parked it, which turned into too much of a hassle for having so little extra time so as you can tell by the miles it sat most of the time.... where im getting at with my escort i was near evo territory with slicks and my vj20 at 11psi (13.7) , id love to be in the evo psi territory (18ish psi) and put a hurting on him without trying.
basically this will be a themed build, that wasnt figured out till about 2 days ago when i started tearing it down... that theme is - do it right the first time.
