has anyone here filled their mounts with urethane? Or used aftermarket ones?? Did you notice any gains.....how did you do it? THanks
Motor Mounts....
uhh...gains? You can't see gains with motor mounts. The reason you fill them is to reduce wheelhop which can help your launches.93' Noble Green MX-ZE (sold )
Originally posted by skr33t_rac3r
u can get some torque loss with too mcuh motor movement so u can acctaully save power but not really gain it
yes, but you will need to have motormounts made of spegetti, and your torque loss willl be due to your engine being on the ground not in your car.
harder engine mounts will make your vcar vibrate more. the whole reason for softer mounts is to buffer the ampitude of the natural frequency at which the engine ossilates.
why do you think engine mounts are made of rubber and not solid steel?When you turn your car on... does it return the favor?
Originally posted by goldstarYes, still have it. It was my attempt to immortalize you in verse.
A Protege driver named Brock
So his engine he goosed
With much too much boost,
