Check Engine Light!
    Check Engine Light!
    I dont kknow what happened but all of a sudden my check engine light started flashing and then its like my car is choking or hesitating. I m thinking its the fuel pump but that wouldnt make the check engine light come on, would it? It flashes like 3 times then stops then again, anybody have this problem? Is there a way to read codes?
    http://profile.myspace.com/index.cfm...e-eda6ab70c99a
    Looking for local enthusiast's to help me out, with some Mazda mods, im new to the mazda scene and im not used to it, Im an ex-honda guy! lol My car needs some tunning and checkup.
    the 3 flashes is the code
    ._________________________
      Also I felt bad for just leaving you hanging sorta
      its code #3
      on DOHC no G signal, Cancels 2 group injection
        locate the diagnostic box in your engine bay. It will be in between the battery and the firewall. Open it and jump the 10 and ground(all this is performed while the key is off). Now get in and turn the key all the way on without starting it. This will shoot some flashes. Inbetween each set of flashes is a pause. count the flashes then come back and let us know what code you have and I'm sure someone can answer what the code is.
          its code #3
          Sorry but what does that mean? my injectors are bad? Wel it flashes 3 times one after the other then pauses, then again 3 times.
            I looked at it good today and i think its code 12 - Throttle sensor.
              THat would be your Throttle Position Sensor. I have priced one around here at O'Reilly Auto Parts and they can't even get me one. But at AUtozone, they can order it for me for $60.
                Thats the one on the throttle body right?
                  Yeah that is on the throttle body. I have tried to adjust mine so that my valve plate isn't open, but I can't get it adjusted correctly and figured that I would buy anew one just to be on the safe side. It's probably about time to change it out anyway.
                    Well i swapped it out yesterday but my idle is off just s little bit and the light is still on. I was thinking it could be code 10, what exactly is that though? Someone else told me to swap put the mass air flow sensor.
                      how do i jump the 10??? someone please show me.. pm'me thanks!!
