motor mounts 1.8l
    motor mounts 1.8l
    anyone here done motor mounts? is it a hard job to do. i think i may need to replace some mounts sense i have some noticeable engine rock but im not sure if i should get into it in my driveway
    I did mine in my drive. The rear one is the most annoying to line up.
    Drew
    '95 EGT 1.8
    T
    '93 ELX 1.9 SC
    '91 ELX 1.9
      they're not that bad man. your best bet if you're doing both mounts is to drop the crossmember that they sit on. I'd pick up some silicone and fill the new mounts in so they don't flex as much.
      JACK.
        yeah ill do that, i had a mx6gt before this car and i did the same thing but that car was a bitch to get them in so i just paid to have it done
          Do not use Silicone. It does not bond to the rubber in the mounts and will fall out.
          Go to NAPA/Carquest or a store like that which sells "Windshield Installation Urethane". That's the stuff you want to use to fill motor mounts
          Drew
          '95 EGT 1.8
          T
          '93 ELX 1.9 SC
          '91 ELX 1.9
            i remember silicone working. does the window stuff set pretty hard? i dont want these to feel like poly mounts. ive gone that route and its not nice for a daily
              oups, thanks Skuce, i was a bit hung over still when I wrote that up :D
              It's not that hard NJ, i'd recomment doing AT LEAST the rear one since the front mounts are fairly strong. Rear ones are weak and can be a pain to change sometimes.
              JACK.
                3M window weld. I've seen it in autozone.
                  science experiment bushings
                  the gob on the left is some polyurethane paint I left in a jar a few days ago. 5 days later it feels almost as hard as the ST bushing beside it.
                  I'm going to check it again in a few days (walks away mumbling equations) LOL!
                  Got some black left so I'll try it on a worn out mount
                      just get the zxtuner inserts for the motor mounts it stiffens them right up i got them in my car big difference in a good way
                      sigpic gtx swap,pacesetter cat back exhaust,civic short shifter,both front and rear upper strut tower bars,high flow cat,,mx-3 lower tie bar,mx-3 front seats,zxtuner poly motor mount inserts,manual seat belt conversion,mx-3 lether shift boot,
                      come to mazdasnw.com if you live in the northwest
                        Did it to my rear mount and it's still workin' great.
                          I had them also, they work well and are easier than attempting to cast in urethane.
                            well as we all now know, there's more than 3 ways of stiffening up your mounts. if anyone has any feedback as to how long it took to dry, how easy it was to work with (the material used to fill them) post it up!
                            JACK.
                              I have the Energy Suspension urethane inserts on the GTR. It gave the car a rough feeling at idle but it has a great feel when driving.
                              1991 Mazda 323 GTR Sedan
                              MODS:
                              GTR motor swap, F&R Familia strut bars, MX-3 Rear Lower strut tie bar, GTX front bumper, GTX grill, EDM headlights & corners, EDM 323 rear garnish, EDM spoiler, EGT sideskirts, MX-3 seats, GTX steering wheel, EGT glass sunroof, WRX hood scoop (functional!!), and other things that take too much space to list.....
                              TO DO LIST:
                              EDM/JDM rear bumper
                              EDM/JDM power folding mirrors
                              Repaint car
