VJ-11 install
    There are b6ts pushing 80 bagillion hp on stock blocks. What I meant is that the most horsepower with bolt-ons and stock turbos I've heard of is around 200 whp. IMO the vj-14 isn't worth that much work, you can get more horsepwer for cheaper by adding more airflow and bigger turbos. If you have a built engine you could make gobs more power with even an 11/t-bird and still have a very responsive car or do something like an 11/8 and have a sick drag powerband.
    Fast, cheap, reliable: pick two.
    1992 Mercury Capri XR2 130xxx miles SOLD
    1990 Honda Civic SI
    186k 10:1 hybrid motor
    d16 on 10 pounds will turn ya out.
      yeah over 200 on a vj-14 is pretty uncommon.
      1988 White GTX - #1 parts
      1988 White GTX - #5 Rally car
        What about hybriding the stock exhaust side to a vj-11 housing and compressor. For us guys who need the spool because drag racing doesnt really mean much. I remeber there being some info on the old site but i thought i would read it when i got the two turbos sitting infront of me.
          That would be an 11/14 hybrid which are really quite common, probably moreso than actual vj-11s on b6ts. Honestly I don't think that the spool is bad at all, it's almost too fast for me as a daily driver, I can't keep t out of boost accelerating with traffic and spools way faster than any aftermarket turbo set-up I've ever driven. Definately not a dog by any means and the extra power is un-****ing-beleivable.
          1990 Honda Civic SI
            I believe you cause i can't keep my turbo from spooling, however i am all about keeping the turbo as fast spooling as possible, faster spool does mean faster lap times on a tight course. But on a wider coursei believe the vj11 would be a good choice. Hell i would do it...but ya know.
              It's your car, do what you want but I'm fairly certain that with an exhaust a vj-11 would spool every bit as fast as a completely stock car an even with a stock exahust I still think my car would kick ass on a vj-14 car on everything but a really really tight gymkhana style auto-x. but this is all IMO, do as you will.
              1990 Honda Civic SI
                I've been running the VJ-11 for about a year and a half now, I see full boost (running 20psi) by 3500 and I love it. The problem i have is with the stock rev limiter... the motor is still pulling strong and i almost ALWAYS clip the limiter in 1st....
                1988 323 GTX
                  do you all have anypics of your down pipes with the vj11? im just trying to see what needs to be done there???? thanks alot
                  '95 Ford Escort LX, GTX block .40 over, wiseco 9.1 pistons, gtr rods, gtx head, MS1, 550 inj. T3/T4 .57 Trim, DSM BOV, WALBRO 255 FP, civic half rad, MSP LSD, stage 3 kyclutch, ebay short shifter, mx-3 rear tie bar, AEM wideband....SHE IS ALIVE
                  '88 Mazda Gtx AWD B6T engine Ported head, VJ-11, EL prototype chipped ECU, Blitz SBC-iD electronic boost controller, Full HKS exhaust, Centerforce dual friction clutch & more
                    well i guess im gonna be one of the uncommon guy who makes 200whp on a vj14....im @ 190whp and i dont even have a front mount yet...
                      ^set-up? boost?
                      1990 Honda Civic SI
                        over 200whp on a VJ14 on a B6(t)??? id like to see that. i don't think the VJ14 has that flow capacity does it.
                        the vj11 should never run 20 PSI... you should worry about it blowing up @ anything above 15psi
                            hey bpt323 i know my turbo wont make ne more power. But u dont think ill make a lil more when i get my front mount, cams, etc.... well lets c what happens
                              Of course it will make more power but IATs will go through the roof and longevity will suffer. Just swap turbos, I didn't pay more than $100 for any of mine, and didn't you say your turbo is blown? If you want more power than that do the 11/t-bird swap, 350 cfm maxes out at 22 psi, or look around at Probe GT forums, they have all sorts of information on how to install bigger turbos.
                              1990 Honda Civic SI
                                nope i dont have a blown turbo. and i have a vj11 which i paid about $57 from the junk yark off a MX6. Its ported and ready. I just wanna get a 255 fuel pump and mx6 turbo injectors. Im just reading as much as i can on that turbo swap. And i wanna do my front mount and hit the dyno to see my powa gain before i swap my turbo. I also have a T28 which i think needs to get rebuild. Its just a bunch money issues these days.
