Sock's BP-Swappin' 323 Project Thread (Comments Appreciated!)
    Making myself a flange.
    Original vs. Planned (actually went with a slightly modified 45* bend for more awesomness)
    Blasting a hole.
    Original vs. 45* Downpipe
    Test fitting.
    Sizing up what I'll need.
    Welded some flanges on.
    Test fitting.
    Made an overkill bracket to mount the cat.
      Dude, Pure awesomeness!
      I wish i had a shop to park my car in and tear into it.
      I need to rebuild the sum bitch
      Mazda
      1988 Black 323 GT
      DOHC 16 VALVE TURBO
        WOW... makes me want to just go out into the garage and start tearing stuff apart to be closer to starting my BP build and swap
        Man, u take no prisoners!
        Ex-Officer: INTENSE Performance Mazda Club of South Florida
        JDM nut & AutoXer: 1992 Blaze Red Mazda 323 S
        262,000 miles and kickin... and got some wicked new goodies recently...
        BP Engine Build: Soon... Engine on the garage floor, parts on order
        "Ever seen a 323 on Anthracite 17" OZ Superleggeras?!?!
        ...... and more importantly ever seen one with matching 15" Superleggeras for Autox??"
          Added the straight section.
          Added a hanger
          This is the funky piece that goes over the rear suspension
          Painted the front downpipe from manifold. High heat flat black.
          The rest of the exhaust got high heat silver since I was too dirty/lazy to go buy another can of black. Looks fine anyways.
          And a turn to go around the gas tank,
          And into the muffler.
          After the muffler section gets painted black (to hide it even more), it should look fairly stealthy.
            One thing about your hose running to the brake booster. You may know this, or maybe not, but the OEM hose (although it just looks like a hose with some steel tubing) has a check-valve in it. It looks like you just put a long piece of rubber hose in it's place. If so, you may see some trouble with your booster not working properly. How do I know this? My first rally car suffered from this problem, no check-valve, trying to stop after full throttle = very little braking power = very scarey high speed cornering in the dirt!!
            Looking great, keep up the good work...
            -Jon R.
              horray for the way welding galvanized steel looks!! lol
              may want to sand or grind that coating off before welding in the future, i mean the welds work fine, its just a little harder to make um look nice
              95' mx-3 BPT GT28r
                -Jon R.
                I will toss it back on there after fixing it (I bent the end of it when dropping in the new motor ), so I'll just need to cut and re-flare (bubble out) the end to get a good clamp spot on it. Thanks for the heads up.
                Also, I wasn't aiming for the welds to be pretty, just strong. I'm also a crappy welder and using a 220v arc makes for some learning on this thin exhaust tubing. lol
                I still have to build one mount for the pipe that goes around the fuel tank, clamp on the muffler (incase I decide to switch in the future, easier to change out) and then weld on the tip/exhaust pipe piece.
                Then, I need to build myself an intake system and get on with this thing!
                  Actually, the check-valve is in the rubber hose section. I fixed my rally car by using a plastic check-valve out of a Honda Prelude. Pretty much any check-valve that goes inline to a brake booster should work though. Some cars have them in the booster itself. And at a glance, Mazdas seem to be that way. Even without it, you may never have a problem. I mostly noticed it when I started left foot braking. (rally driving technique for rotating a fwd car faster around a corner, on the gas and brakes at the same time)
                  Arc welding is tough and rarely good looking. The mig welder is my favorite tool in the shop!! :-)
                  -Jon R.
                    Originally posted by Sockington View Post
                    ouchy car cancer, car cancer
                      thats canada for ya lol
                      lookin good man!
                      JACK.
                        lookin good man!
                        JACK.
                        LOL speaking of which....... just got off the phone with my GF.... she is in windsor right now on a business trip.....
                        she's been looking for 323s and stuff while driving around and nothing
                        also noted that there are NO scions up there??
                        PM sent re: goodies she can maybe bring down.....
                          There's no cancer there, just crappy surface rust on the rear suspension.
                          Didn't I happen to mention that I have that whole Escort GT rear subframe just hanging about (going to clean it, paint it, install that).
                            Getting started.
                            Oh? What's that? A chunk of my paycheque today, that's what.
                            Button up the hoses.
                            Getting the front end re-installed.
                            I think these might have a new home when not installed on the MR2...
                              Looks good! How much more is left to hook up?
                              Mazda
                              1988 Black 323 GT
                              DOHC 16 VALVE TURBO
                                its comin along! FYI you can cut your headlight/corner lower lip to fit in there so there isn't a huge gap.
                                love the rims tho!
                                JACK.
