GT-R Gearbox on B6T in BF.
    Hi im new in this forum
    Is it possible to bolt ut an GT-R gearbox on a B6T in a BF?
    Is it whort it?
    It won't bolt straight up, you'll need to mod the xmember. Two of the bellhousing bolts don't line up but iirc they aren't terribly important ones. The front lower trans mount will need to either be modded or fabricated, I think, with a b6t but I'm not certain. If you have a GTR mount you may be OK. Then, you'll have halfshafts that need hybridizing in order to work. But that VLCD is a cool thing to have, and the gearset's some stronger.
      Ok thanks Sorry for writing in the wrong section, mod move this thread?
        i need to mod the driveshafts? do the rear difirential bolt up?
          Yeah, it's compatable with the rear diff, and the rear driveshaft bolts up. you'll need a set of inner front halfshaft from a BG car and mate them with the outer CV's from your car.
            Thanks.. just baugth my second BF GtX today, so all my money is going in to it
