1st gen CEL codes?
    1st gen CEL codes?
    So i can't find that full list of CEL codes for the 1st gen anymore? wtf? anyone have the link handy?
    also anyone know the BP firing order for the cap?
    JACK.
    If you need me to send the fsm to you again I'm going to be signed on aim all night til I crash. I can send it too you again
      naw, i dont need the FSM, i forgot to even look in the damn thing. i was use to lookin up CELs on here haha.
      JACK.
        ok, FSM = sh-it for trying to find CEL codes...
        anyone have the link or know what code 03 is? i cant remember....
          code 3 is disty home signal. your disty is fked
            damn, that sucks...i wonder if it has anything to do wtih me running a B6 disti on a BP right now just to compression/leak down testing. i know the disti was fine before this.
            JACK.
              JACK.
              1,3,4,2 clockwise. 1 is labeled on your cap.
                bumping this, anyone have the link to the list? CEL codes should be stickied! i'm pullin a code 25.
                JACK.
                  code 25 is solenoid valve (pressure regulator)
                  In the FSM look under section F > self diagnosis
                  ._________________________
                    can someone get a scan of the codes up here already!!
                      This is what shooting the code is, you can do this in your driveway with a paperclip.
                      Copied from Haynes manual.
                      Pulling Codes 1990-1994 Protégé/323
                      1)The PCM (computer) has a built in self diagnosis system which detects malfunctions in the system sensors and alerts the driver by illuminating a CHECK ENGINE warning light in the instrument panel. The computer stores the failure code until the diagnostic system is cleared by disconnecting the negative battery cable then depressing the brake pedal for a period of five seconds or longer. The warning light goes out automatically when the malfunction is repaired.
                      2)The CHECK ENGINE warning light should come on when the ignition switch is placed in the On position, this checks the bulb for proper operation. When the engine is started the warning light should go out. If the light remains on, the diagnostic system has detected a malfunction or abnormality in the system.
                      3)To determine which sensor or system component is malfunctioning, connect a jumper wire (paper clip) between the TEN and GND terminals at the DIAGNOSTIC test connector in the engine compartment. Make sure the battery voltage is greater then 11 volts, the transmission in Neutral, the accessories are off, the throttle valve is closed and the engine is at normal operating temperature, then turn the ignition switch to the ON position but do not start the engine.
                      4)The diagnostic code is the number of flashes indicated on the CHECK ENGINE light. If no codes are stored, the CHECK ENGINE light will come on for a few moments, then go out. If any malfunction has been detected, the light will blink the first digit(s) of the code at a long interval(s) and then blink the second digit of the code at short interval(s). For example, a code 34 (IAC valve) will first blink three flashes and then pause and blink four quick flashes. NOTE: If the code is simply a single digit number, the CHECK ENGINE light will flash in the quick mode.
                      Codes:
                      02 Distributor Ne-signal
                      03 Distributor G-signal
                      08 Airflow Sensor
                      09 Coolant temp. sensor
                      10 Intake air temp. sensor
                      12 Throttle position sensor
                      14 Barometric pressure sensor
                      15 O2 sensor
                      17 O2 sensor has detected a rich or lean condition
                      25 Solenoid valve (fuel pressure regulator)
                      26 Solenoid valve (purge control)
                      34 IAC valve
                      41 Solenoid valve (VICS)
                        I stuck this because Jo supplied great info. Thanks Jo
                          Sticky icky
                            my protege is pulling the code #14 and i got a new ecu b/c the Barometric pressure sensor is in the ecu but i still have the same problem help me ppl thanks
                              ^^^bump?
