Oil feed line banjo bolt alternative
    Originally posted by Kitty View Post
    What are you going to do with the stock bolt?
    Spare
      I love spare parts
      ._________________________
        nice find, i can't beleve i did not see this earlyer, well im in need of the same banjo bolt and i need asap,(i forgot to get the mazda one) want the car running this weekend.
        so whats the part number and do you know the car/truck year is from?
        also what size drill bit did you use to open it up bigger.
        from the package it looks like (help part number 13940)
        calapier hose banjo bolt.
        thanks
        5 boosted bp cars,why...
          the size of the hole should not matter, the oil restrictor is in the fitting on the top of the CHRA
            well i would like to know anyway, im running a russels 3an line and restrictor(can't rember size at the moment) at the turbo ( turbo is a small .42/.48 t3)
              I have no clue. I basically just found a bit that was the same size as the hole and just drilled away.
              BTW I'm currently running this bolt and it works just fine
                m glad its a sticky now it's a great find, i went to napa and told them i need a caliper banjo bolt for a gm, i told them i did not know what is from but i have a part number, brand is help part number 13920, they got me the right one treads in fine,
                know turpro, can you check your backup/spare(oem mazda one) to see what size drill bit fits it, i would check mine but they are on all of my boosted cars know and i don't want to pull one off.
                  Thanks.
                  I basically just grab a bit that was the same size as the hole that's in it(the gm bolt) and drilled it all the way thru. I didn't make it the same size as the oem mazda on. Works perfect so far so no need to drill it bigger.
                    Post up the full UPC code on the back of that banjo bolt package.
                    Also...the restrictor on the VJ20 is on the top of the center housing of the turbo itself. You have to have it or the oil seals blow on the turbo.
                    Drew
                    '95 EGT 1.8
                    T
                    '93 ELX 1.9 SC
                    '91 ELX 1.9
                      Here's the best shot I can do with my crappy cam.
                        kk. I'll punch that in at work tomorrow to see if I can get them in.
                        Drew
                        '95 EGT 1.8
                        T
                        '93 ELX 1.9 SC
                        '91 ELX 1.9
                          I think they're in every autoparts store in the "help" section. There's 2 banjo bolts next to each other. 1 is gold(the 1 you need) and the other is silver but I think the silver 1 was too big IIRC
                            Earl's Performance has lotsa banjo fittings...
                            More fittings if you wanna go AN styles...
                            Member of MX-3.com
                            "Do it ONCE, do it RIGHT!"
                              Thanks . An fitting will be my naxt upgrade along with braided line.
                                how is that an upgrade the factory lines work just fine
