Kia Tranny how - to installl
    For the pros... to post up.. for search purposes..
    copied from the FS thread in which you asked:
    kia axles, jackshaft, mounts(just the upper brackets the rubber mounts work) and atleast for me i needed the slave cylinder and had to rebend my clutch line
    tho I have heard some Pro LX and EGT owner have used there stock slaves
    also the front lower mount is really close to the radiator fan support (less than a 1/4 inch)
      preciate it....again..lol ill sticky this!
        can someone ban this dude
        94 Pro LX- 3-hole. Familia seats, Infini Corners, Familia Grille, Familia Rear Garnish w/Rear fogs EDM Glass headlights,
        MSP Mazdaspeed Muffler,Mazdaspeed front strut bar,'00 Pro ES wheels, Neuspeed Springs,GR2s, MX3 wheel, MX3 Tall armrest
          banhammered
          speaking of this thread i have pics to add
            Please add!
              bump for pics
              MY DRINKING TEAM HAS A RACING PROBLEM
                dammit i forgot about that. need to go get them off my laptop
                  for a protege LX or escort GT it bolts right in, just like stock. the only thing you have to do "different" is use the kia axles and jackshaft, but they fit like stock as well.
                    Wow, excellent thread, this is for sure in my favorites.
                    Thanks!
                      correct me if i am wrong, put the kia has more lines (english is my second language) in the cv joint
                        Yes, it has 28 splines versus 26. That's why you need the Kia axles and jackshaft. Or, you could put in a 26-spline MFactory lsd and re-use your stock axles.
                        --Ferdi
                          whats the name whre it goes the whell, and the ball joints, because you need to change that also, other wise the cv joint will not fit.
                            Nope, the hub side is the same between the Mazda and Kia.
                            --Ferdi
                              what did the Kia tranny come out of? Make/Model?
                              1988 323 GT - B6T Powered
