WilyB's 93 GT rebuild
    It is completely safe on plastic, the silkscreening is still on the levers, and yes Canadian tire in Canada and true value in US. approx 10$ canuck for a 1liter bottle...
    Hey Thanks for the G2 progt91... I'll check that out...BTW a friend here is parting out a 91 GT and is now parting out an SOHC as well.... blew the tranny on it last week... I just found my gas tank, exhaust system, door locks (if you look up, the car was broken into a couple of times and they used a screwdriver on the locks)
    91 GT- Li'l Bee (under construction)
    2013 Honda Accord V6 coupe - 14.7 sec. 1/4 mile
    New Thread:
    Wilyb's 91 Pro GT Rebuild: Li'l B: http://www.clubprotege.com/forum/sho...Rebuild-Li-l-B
    Old Threads:
    WilyB's 93 GT rebuild worklog : http://www.clubprotege.com/forum/sho...-93-GT-rebuild
    My FE3 worklog thread:http://www.clubprotege.com/forum/sho...ighlight=wilyb
      oops not there... here it is...
      New Thread:
      Old Threads:
        I found an interesting article on rust removal explaining phosphoric acid's uses and other methods. I sent a question to the author regarding who it affected paints. I'll post the response when I get it..
        Yo Crep, he talks about the electrolytic rust removal method as well
        PP
        New Thread:
        Old Threads:
          Tell me what you think... if you look above you will see my passenger door with a big hole next to the lock.
          I'm debating on how to fix it. I have a new lock and a door. I can either just cut out ( around) the lock hole from the good door and do same with my current door, then epoxy the replacement hole onto my door, a bit of grinding, bondo, prep then paint.
          Or I could replace the entire door. That means a whole bunch of parts replacement, sanding painting etc., not to mention that my current door is actually in better shape.
          I can't just bondo or fiberglass around the hole because the lock clip then would not fit around the lock barrel and hug properly against the interior wall of the door.
          New Thread:
          Old Threads:
            I say weld a piece of metal in place of all key locks and get an alarm that unlock the doors for ya
              Man i need some of that stuff on some parts i have... where did you get it??
              Hea Tur you think i can use it on torn down hubs Lateral arms and lateral links before i paint them?
              Looks easy and a way faster way to clean them up then sanding...lol
              Hea WilyB did you do any extra sanding to get them that clean??
                Nope none at all... you can buy it at true value hardware stateside... its named evapo rust...
                Here are some other options:
                New Thread:
                Old Threads:
                  Phosphoric Acid has a unique property of dissolving iron oxide (rust) quickly while etching iron very slowly. This means that you can leave metal in Phosphoric Acid for much longer than necessary with very little damage. The acid will attack bare metal slowly and will start the process of hydrogen embrittlement, so use the minimum etch time that removes all rust.
                  New Thread:
                  Old Threads:
                    Another unique advantage of Phosphoric Acid is that it leaves a fine coating of iron phosphate behind. Iron phosphate prevents rust. However, the iron phosphate coating is not very thick and not durable. Some additional protection is still required.
                    New Thread:
                    Old Threads:
                      Phosphoric Acid etch will leave a hard, bright metal finish. This is because it will etch the surface slightly, exposing new, bare metal. Often this is desirable. It leaves an attractive surface and a surface ready to paint...
                      New Thread:
                      Old Threads:
                        Where to find it: although difficult to find, they sell it at your neighbourhood Hydroponics store... You know.... where they sell the stuff to grow killer weed...lol...
                        New Thread:
                        Old Threads:
                          Why is it I can only submit 2-3 friggin lines?
                          New Thread:
                          Old Threads:
                            shrug...works fine for me
                            http://wihandyman.com/forum/showthre...371#post495371
                            Posted By: Wheresthericego
                            The BP crank is made out of invincible.
                              i was just reading through and that rust looks harsh, theres another thing that works well on rust, named ospho, paint it on, leave for 24 hrs, dust off whats left, turns the rust black (think it does the same iron tannate thing lol)
                                Originally posted by progt91 View Post
                                get it from the wreckers from an escort, thats what i did they are galvantized so they are in much better shape then the mazda ones
                                I don't know how bad the Mazda ones get, but of the 14 or so Escorts we have (between my boss and I), a majority of them have surface rust on the filler pipes and a few are rusted through, even on cars that are otherwise solid in that area.
                                92 240SX: KA/T25, nerd mobile
