braided line and fitting question
    What size AN fittings(block and turbo side) would I need to run a braided line to a vj11/vj20? Also what size line would I need(not length)? Also how long of a line(guess I should ask lol)?
    yes i would like to know as well. i read that wtrg says about 20 bucks. hell if thats with fittings its much cheaper than stock lines.
    i found on feoa a guy who said M10 x 1.5 to AN3 is the fitting we want but i cant find that anywhere.
    1994 Escort LX Wagon
    2013 Hyundai Veloster Turbo
    91 EGT - Junked May 2012
      found a fitting. i cant find an 3 but i found 4
        Also what about the oil restrictor? Where can I get 1 and any specific size/demensions?
          bump.
          so does anyone know the diameter of the restrictor hole on the turbo?
            lines r 3an as far as the banjo bolt, Im not sure, just know it has a metric size and length....I can check tomarrow when its light out
              Anyone actually find the answer to what's on the block side for fittings?... I am wondering for oil and water?
              Member of MX-3.com
              "Do it ONCE, do it RIGHT!"
                They say you'd need a .055 to .060 hole diameter for a journal barring and around .035 for a BB
                I have a little something in the works and for oil feed I'm going to use a -4 line, but I'd think a -3 would work to...I'd just go a little bigger hole on the -3 and smaller on the -4.
                  I read on the aussie sites that the thread on the oil feed from the block is really odd - never found the answer when I was looking for it. You could order the banjo bolt from Mazda and make your own line with a banjo end.
                    water doesnt use fittings....per say I beleive its a barb fitting, on the block side...but cant remember..might plumb right back into the coolant pipe that runs infront of the motor, I'll have to check on that....and I beleive I have an extra banjo bolt lying around that I will try and get measurements on this weekend....if I have an extra.....lines are 3an to the oil inlet and 6an sized hose for water lines, but might not be able to use 6an fittings.... the inlet and outlet for coolant on the turbo are also banjo bolt and barb fittings...I'll see If I can find the fitting size for those as well
                    granted these sizes are for a t3/vj20 but I wouldnt think that they would differ on just a vj20....basically I'll go this weekend and try and get all the an fittings lined up for a complete an type setup for the turbo
                      If I recall correctly it's m 10 x 1.50. Which is a little on the odd side. They really should have made it a fine thread fitting I think.
                        OK here's what I came up with...
                        The oil feed is M10-1.50
                        see I even took pix...
                        And the coolant is M12-1.25
                          Excellent... you are the best!
                          Member of MX-3.com
                            sweet!
                              Thought I'd share my findings for anyone that's looking to adapt to -4AN...
                              Oil feed fitting from M10 x 1.50 to -4AN Flare
                              Water feed fitting from M12 x 1.25 to -4AN Flare
                              Member of MX-3.com
