GTX build thread
    GTX build thread
    Figured I'd start a document on the build-up of our shop GTX.
    First off, it blew up on me while I was boosting 15psi in 4th gear, I didn't really know what was going on at first, but it was definatly only running on 3 cylinders lol. So I limped it back to our shop and the tear down began.
    Here's a couple shots of the car with the FMIC and piping I built for it.
    And here is the wonderful internals of the engine after some detination:
    Burned exhaust valve
    Top of piston
    Hi there Mr. Ring
    Bare block
    So we are gathering parts for the build as we speak, hoping to get it together very shortly and back in the car. While everything is apart, we're fully rebuilding the tranny and doing some body work.
    Cars Suck...
    nice piston, keep us posted. anything special for the engine build?
      That piston is re-usable. Just sand it down a little. lol. Sub'n to watch the progress
        LOL, yeah I should just giver a polish, it'll work just fine haha.
        Our first step is to take the block to our machine shop and see if its even usable for the JE pistons we're getting. Then we'll go from there.
        Cars Suck...
          I contacted our supplier and they dont have any listing for ARP studs for the B6T. Does anyone know a part number or if the Miata ARP stud kit will work with our engine?
          Also, the 10 thou over pistons aren't going to work with our damaged block, we need to bore it at least 20 thou over, so we are looking into getting some new pistons for the build now.
          Cars Suck...
            I know that wiseco has .20 over pistons for the b6... might have to go with a higher cr though i don't remember. I'm almost certain the arp studs are swappable between b6 miata and b6t
            1988 White GTX - #1 parts
            1988 White GTX - #5 Rally car
              UPDATE:
              Been a little while and lots of stuff has been happening.
              First off, the blown up engine is now going to be a spare because we scored a freshly rebuilt engine with some aftermarket goodies on it for $600.
              We're going to run the stock turbo again, but this time better boost control. I hogged the wastegate hole out almost double the size of stock.
              I just picked up the transmission today from our rebuilders.
              The body work is coming along slowly, we're only working on it in our spare time but its going to be one of a kind!
              Pics to follow....
              Cars Suck...
                Wide body?
                  Yeah sorta, fender flares for uber wide rim/tire combo
                  Cars Suck...
                    nice how wide you trying to go on the wheels?
                      I think Dan has a set of 15x9" wide all around on order with a zero offest
                      Cars Suck...
                        be sure to port that piston while its out!!! o.0
                        ._________________________
                          Umm detonation - looks like it happened for a good while. Was it a bad injector?
                            No, injectors are good, just had them flow tested today actually.
                            It was a combination of waaay too much boost and no supporting mods. It would bounce off 18psi in 3rd or 4th gear once in a while and stutter real bad. LOL, it was only a matter of time.
                            Cars Suck...
                              Pics....
                              Cars Suck...
