Well as I've been posting in the other section; I've been messing around with the cooling system alot; and solving alot of leaks, and spurts.
As such, most of the engine compartment was bathed with antifreeze! At some point I used some cheap, raunchy smelly antifreeze (had to make it home) and some of that even spelled onto the engine, now whenever she warms up, or gets to "operating" heat, you can smell the crap burning off the engine.....
So, I wanted to make a trip to the car wash and get some of that engine degreaser/cleaner on there and clean it up. Keep in mind also, this is a 1991 Protege; and SINCE 1991, I'm the only one to actually do anything to the car under the hood...which means the engine is DIRTY!
I know I need to cover the disty, but do I unplug the spark plug wires and cover it and then go from there? Or leave them plugged in and just cover it with a bag....I'm at a total loss for what to do to protect my car from the water. (Then again, I don't have a splash guard, so I know most of the engine has been hit with water before...as I drove in water that went to 3/4 of the wheel height)
