Replacing 4th and 5th gear without dropping the tranny?
    I was wondering if the tranny needs to be dropped to replace 4th gear on a G series tranny, or if it can be swapped without dropping it?
    I read an article where you can easily swap the 5th gear without dropping the tranny, but what about the 4th gear?
    Sorry I am not much of a tranny guy...lol
    Thanks
    93 EGT 5M, Bimini Blue
    132k miles, DD only
    0w20, EG Fram Oil Filter for Probe 2.5L, Magnetic Drain Plug, ebay cone filter, 03 Protege Rotors, moog sway bar end-links on rear sway bar, mx3 seats, Power Sunroof, Miata Valve Cover Bolts, Gatorback Belts, Timing *14 on 87 Oct, Autolite 3924 @ .043 - 35 mpg at 67 mph (95% highway driving) with A/C and headlights on. Untested for fuel economy: Sylvania EcoBright 9004, .717 5th gear with D6 ATF, NGK wires, 195/65/15 Kumho LRR 4 wire tps
    Former Car: 92 Protege DX 5 spd.
    You have to take the tranny apart to 4th gear. 5th and reverse are under the small cover on the driver's side, and you don't have to drop it to get to those.
      not possible. only 5th can be accessed inside the car
      ._________________________
        why does 4th need changing? broken gear, different ratio, or just maybe the synchros going bad?
        --sarge
          You also need a gear puller to get the 4th gear and bearings off...unlike 5th. Can be quite a pain in the rear to do without damaging anything.
          BG Astina + GTR convertion + Microtech ECU + FMIC + 3" Exhaust x 21psi boost = 12.168sec to the power of 326whp
          Here's My Worklog and My YouTube Videos
            a press works much better than a gear puller.... but yeah as rob said you have to press the bearings off of the ends of the shafts (plan on getting new ones) and then press the gears off. then you need to press the new ones on.
              --sarge
              Different gear ratio...still a little bit too low for my liking...I am not going to sweat it though.
              I just looked at my tire size, and they are 185/65 14 a curse for most, but that should help me meet my efficiency goals.
              132k miles, DD only
                Thanks to the rest of you.
                132k miles, DD only
                  Can you run 13" wheels on your DX? I've got them on my BP'd 323, with 155/80-13's. I'm only getting 32-33mpg, but that's at 75-85mph, with the windows down, and for some silly reason, I find it very hard to take of slowly and gently all the time...
                  --sarge
                    --sarge
                    Gently =! slowly
                    At highway speed, I have just my big toe resting on the pedal to maintain 60mph.
                    Even then, I still start pulling up to 70+...
                      imagine only having 4th......
                      i cant help but pound it to 80-90 sometime since @ 60 im right in the BP's powerband :D
