Wondering if anyone can give me a hand with this. I'm adding power door locks to a Canadian Protege SE (different than a US SE). I was able to add the motors and acutator to both front doors (no acutator on the drivers door) without any issues as the plugs for the wiring were already there.
However, when I went to install the power components to the rear doors, there was no wiring. There isn't any wiring between the door and the frame either, there are only black plugs covering each of the two holes. I'm assuming I need a harness along with the rubber hose but once I get the harness, where does it connect to and where is routed to?
Also, I can't locate the plug that the relay connects to. I know it should be somewhere above the clutch pedal where the other relays are connected but I just can't find it for the life of me. I'm guessing there should be one as the front doors were prewired for the locks but it just doesn't seem to be presenting itself. Anyone have any ideas?
Thanks in advance.
Thanks in advance.
