Yes , winter his approaching and im starting to buy my stuff for my BPT.
And i would like some help , advice from u guys
First , iv noticed that motor was taking , then burning and smelling oil. I think i have dammaged 4th piston, and most of piston ring are dammaged too.
- I buying: 4 wiseco forged piston(0.020 oversize) with appropriated rings and pin lock. Im making piston top ceramique coated and dry lube for the ring set (50 $ each / 2 treatement)
Then lots of smoke was coming out of the exhaust when im starting the car.....most pepeole told me valve seal were bad.
-I dont'know what should i change????.....all valve systeme, only valve seal, only dammage valve seal?!?!...keep stock bpt valve....go with sodium filled gtr one? Should i get the head ported? ceramique coated?
After this , second gear started to enter really bad (feeling resistance) and most of what i red about this bpt tranny is : its the same as escort gt , protégé gt 1991 93... and was kind of cheap crap.
-So i'm thinking about changing the syncro!?!?
Then radiator was bad and had hole in it!!! it got sealed with liquid but i dont think its long term issue.
-i found ss radiator with fan spal slim line, coolant tank for 300$ (should i buy it)looks like it came from corksport.
***I found couple of guys who cando the work.....speedshop from montreal gave me 2400$ for changing piston only and taking motor in/out of the car!!
i think i could find kind of the same price for almost all of my modification buy buying all part before!!
thank you
Club protégé no1
203.5whp 207lbs
thank you
Club protégé no1
203.5whp 207lbs
