Geoff's 1997 Mazda Protege ES Worklog
    Well here it goes, my clutch crapped out me awhile back and the current engine was leaking oil from the valve cover gasket and various other places and I didn't feel like fixing a high mileage engine, so I picked up a 30k donor from Russ McHugh whom some of you might remember auto crossing his 1997 Protege ES in the showroom stock class for awhile. My plans are modest and I only want to have the head ported and polished, with a three angle valve job and 1mm over-sized valves. In addition to that, I plan on using the the 1999-2001 Miata cams for a mild performance gain. For the block, I plan on using the 10:1 1999-2001 pistons and installing a MBSP from a 90-94 Protege. I don't think I will be turboing the car in the near future, I just want something reliable with a little more power; maybe a g-series tranny with an LSD? Who knows?
    Please keep comments focused and relevant about my build and help is ALWAYS appreciated.
    NOTE: All pictures are thumbnails and will link to the larger versions when clicked
    Broke Status FTW!
    Originally Posted on 07-18-2007
    Here are the first pics from the initial tear down of my car prior to pulling the old engine (still need to get a hoist):
    Man I look goofy here.
    It took me about 1-2 hours to remove the lights, grill, radiator shroud, bumper, and ac condenser. Once I get a hoist I'll start to move faster.
    Broke Status FTW!
      Removing the valve cover.
      Valve cover off; looks pretty clean inside.
      Got that pesky intake manifold off and removed all the head bolts (which were a bitch to get out, but thankfully I had a 12pt socket to get the job done )
      Head is off, time to wrap it up and drop it off at the machinist's (I'll remove the cams and lifters later on).
      A look inside the block: looks like it should.
      A close up of one the cylinders.
      My guard cat.
      Broke Status FTW!
        Originally Posted on 10-27-2007
        Couple Updates:
        Went to the machine shop and inspected some progress:
        Going to have the head ported and polished next, but the only work they've done is surfacing and a valve job. Here are some updated pics:
        Broke Status FTW!
          Originally Posted on 11-14-2007
          Update*
          Pulled the engine and tranny out today, pictures will follow tomorrow.
          Broke Status FTW!
            Originally posted on 02-27-2008
            *Update
            Alright, finally got some time to strip down the block a bit more and have a look over it before it gets dropped off at the machinist's to be checked, cleaned and whatever else needs to be done to it (hot tanked, honed, etc.). Engine had about 164k on the odometer when it was pulled and outside of leaky seals, everything looks great to me. Also going to drop off I/E gaskets to have the head ported and polished (just port matching) and get that finished up.
            A look inside each of the cylinders, still looks good to me, how about everyone else?
            Test fitting my MBSP.
            Broke Status FTW!
              Originally Posted 07-01-2008
              Ordered my bottom end parts:
              Main Bearings
              Rod Bearings
              Main Bearing Cap Bolts
              MBSP Bolts
              Miata 10.1:1 Pistons
              All Bought from MMS, so hopefully I can get my bottom end balanced and back soon enough.
              I have some 30k mile rods that are going to be shot peened as well since I can't justify buying forgies while staying N/A for awhile.
              Broke Status FTW!
                Originally Posted on 08-14-2008
                Dropped all the parts off at the machinist's, going to have the engine balanced as well. I also want to have the flywheel shaved down a bit, but I can't decided on the weight. I'm thinking 15lbs so it won't be too light, but not as heavy as the stock one (~22lbs). If anyone wants to throw their two cents in about that, go ahead.
                Broke Status FTW!
                  Originally Posted on 12-13-2008
                  Got these in the mail today.
                  I have so more updates being that all the machine work is done, I've just been ubber lazy as always
                  Broke Status FTW!
                    So, I went outside and decided to put some of my pieces parts together into an engine:
                    Already assembled and torqued the bottom end, but didn't take pictures of that; oh well!
                    I did the following:
                    Installed rear main seal
                    Installed oil pump with new front seal
                    Installed MBSP with sealant
                    Installed old style metal oil pickup tube with screen
                    Installed oil pan with sealant
                    Installed water pump and gasket
                    Torque all the bolts towards the higher end of Mazda specifications
                    Yep, today was a good day today.
                    Broke Status FTW!
                      This is one of the cleanest n/a builds around. The small things are what matters the most and you're not skimping out on them. Good luck the rest of the way. I'll be watching closely
                        bump for flywheel pics
                          Here are the lightened flywheel pictures:
                          Weighed in at 15lbs on my home scale (definitely not precise though lol).
                          On another note, you know that o ring that fits on the towards the top of the oil pump on the back? Yeah, I didn't install that so that means opening and sealing everything again...great, just great!
                          Broke Status FTW!
                            bump for updates
                            ._________________________
                              Close up of the intake port and some of the port work.
                              Pic showing the surfacing.
                              Another pic showcasing the surfacing (no oversized valves or chamber work, maybe with my spare head in the future).
                              Close-up of the exhaust port and port work.
                              Full on pic of all the exhaust ports.
                              Showing the gasket over an exhaust port.
                              Pic of ARP head studs and head gasket.
                              Another ARP head stud and head gasket shot.
                              Pic of the head bolted on the engine (ignore the minor surface rust on the cam caps, it's gone now).
                              Broke Status FTW!
