Tranni seal replacement
    Ok so I have a tranni leak coming form somewhere. I know of the axles seals,speedo gear o ring and shifter shaft seal. Is there any other seals on the outside of the tranni? I have fluid coming from somewhere that has gotten on the back of the motor/tranni so before I do a syncromesh fluid change I want to seal up the tranni.
    Has anyone replaced the shifter shaft seal while the tranni is still in the car?
    Hmm, is it coming from between the tranny and block? It can be the input shaft seal.
      No. Its all over the back of the block and tranni. I'll thinking axle seals.
        i think axle seal too. pretty common.
          mine leakes from the shifter seal and HAHA no way to change it in the car you need to break the trans open, pull the roll out pin out the shifter shaft so you can slide it through the case and install the new seal. one guy i talked to said you could probably cut it off and reweld the shaft back together but i dont like that idea
            Pull back the accordion boot and there will be a nut/bolt there to separate the shift control rod swivel thing from the shifter shaft.
            --Ferdi
              lol, exactly
                Also check your speedo gear.
                  that was his original thought but i have never seen one leak
                    awsome to know!!! i got the capri xr2 trans g25mr but it probably is the same ill have to look when it gets warmer
                      True. Anyone have the part number for that? The last time I did a tranni fluid change I don't remember ever seeing one there, that's why I'm guessing it could be that. I just want all my leaks and crap fixed. She's a good reliable car and with the turbo and all the exterior/interior looking good I want to be able to pop the hood and see niceness as well. I have a bunch of seals collecting dust right now that I've bought and never got around to doing. Well the time has come to make her sweet.
                        i should be able to get a part number for you for that o ring.... but you could just as easily drive down to napa (in the MPV i guess, lol) with your speedo gear in hand and pick out a universal o-ring.
                          Very ture. Hell if someone could just get the seal size I can hit a hareware store. I've never seen a napa here lol
                            i think i have an escort speedo gear lying around i could measure... remind me this afternoon lol
                              Ok so I an placing an order soon from mazda. These are the seals I'm replacing.
                              F003-27-238A axle seals
                              F401-17-131A shifter shaft seal
                              1011-17-443 speedo gear o ring
                              Is there any other seals externally that I need to know about? If so a part number would be appresiated(sp)
