Getting a part from mazda? When you have part numbers for OEM equipment post it here. I will update the 1st thread whenever a new part number pops up. This thread will also help those looking for specific part numbers as well. If you need a part number ask here. This will help update the numbers list. When listing part number give its parts name.
Motor
Gaskets/seals/internals/manifolds/ect
9992-22-000 Oil cooler nut
Transmission
Gaskets/seals/internals/axles
F520-17-628 Primary shaft locknut (BG G series)
G501-17-629A Secondary shaft locknut (BG G series)
F003-27-238A axle seals(G series)
F401-17-131A shifter shaft seal(G series)
1011-17-443 speedo gear o ring[G series)
B455-46-086 shift lever bushingsthe 1s at the bottom of the lever itself)
Suspension
Bushings/struts/springs/ect
Outer (Transverse Rods to Spindle)
Bolt-b-45528113
Nut-b-00139037b
Inner (Subframe to Transverse Rods)
Bolt-b-52828112a
Electrical
Harnesses/fuses/relays/ect
outside
Anything outside the car
Inside
Anything inside the car
Engine bay
Anything not listed above/cruise contol/ac/ect
passenger side heater hose for the sohc
BR70-61-211
Motor
Transmission
Suspension
Bolt-b-45528113
Nut-b-00139037b
Bolt-b-52828112a
Electrical
outside
Inside
Engine bay
BR70-61-211
