Brake proportioning valve
    I need a brake proportioning valve for a 4wd Pro. One of my seals has popped open and started leaking.
    1990 Protege 4WD
    1 3 5
    2 4 R
    i have one from a 91 EGT... somewhere. should be the same i believe.
      I thought they were different. If they are though, I'm sure it's not enough to make any appreciable difference.
      What do you want for it?
      1990 Protege 4WD
      1 3 5
      2 4 R
        20 shipped?
        i'll check the garage tonight for it when i get home and get back to you in the morning from work. internet is down at home
          if not I have one somewhere I think. It is the same with any BG with 4 wheel disk brakes I think.
          1990 Protege 4WD 5 Speed
            Thanks guys.
            *waits for morning*
            1990 Protege 4WD
            1 3 5
            2 4 R
              stayed out a lot later than planned.... totally forgot. i'll have a look this afternoon and hopefully the internet will be working again.
                No problem.
                1990 Protege 4WD
                1 3 5
                2 4 R
                  i can has found it
                  $20 shipped, USPS priority even =o
                  PM me for my paypal
                    PM sent.
                    1990 Protege 4WD
                    1 3 5
                    2 4 R
                      PM returned
                      i'll do what i can to get that bad boy out tomorrow afternoon. depends how long i'm stuck in line at the DMV.
                        Here is my old busted one.
                        Now I can brake with the front too!
                        1990 Protege 4WD
                        1 3 5
                        2 4 R
                          eek! that's odd/scary!
                            Yeah, I've never seen it happen before.
                            1990 Protege 4WD
                            1 3 5
                            2 4 R
