Anybody know what this connector is for?
What is this connector
91 GT- Li'l Bee (under construction)
2013 Honda Accord V6 coupe - 14.7 sec. 1/4 mile
New Thread:
Wilyb's 91 Pro GT Rebuild: Li'l B: http://www.clubprotege.com/forum/sho...Rebuild-Li-l-B
Old Threads:
WilyB's 93 GT rebuild worklog : http://www.clubprotege.com/forum/sho...-93-GT-rebuild
My FE3 worklog thread:http://www.clubprotege.com/forum/sho...ighlight=wilyb
sigpicTags: None
brake master cylinder level sensorEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Either reverse or neutral switch. Pretty sure it's reverse.'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
Too funny Smoke!!
wow... that didn't take long...
Should I be looking for the male connector on that? is it a neutral switch for atx's or std's as well?
I just happened to spot that while I was doing some other stuff and I'm sure I never disconnected it...91 GT- Li'l Bee (under construction)
New Thread:
Old Threads:
i'm still quite sure that it's for the level sensor in your brake master cylinder. trace the wire coming from the master cylinder, see where it goes... i bet it goes to a loose plug.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Originally posted by therieldeal View Posti'm still quite sure that it's for the level sensor in your brake master cylinder. trace the wire coming from the master cylinder, see where it goes... i bet it goes to a loose plug.
