323Permin's 323 SE transformation into a GT
    wow that is one sexy rear end!
    1990 Protege 4WD 5 Speed
      I'm both jealous >.< and excited :D
        very nice
        02 Subaru WRX
        72 Datsun 510
        92 Escort gt turbo
          looks awsome.. very sexy... the amount of wheel gap you have is just fine... Like Lex I have been running on less then that...
            i wish i could get my cars too look as clean as that rear
            88 323 bf (parts)
            88 gtx (project)
            88 gtx (project)
            91 323 lx (sadly sleeping in the snow)
            94 toyota pickup (not happy)
            05 mazda 3 (DD)
            91 mustang w/ 351w (sold)
            too many projects
              wow very nice work
                i have a question i cant remove the bolt that hold the lca to the spindle. what did you do to remove it??
                2012 Kia rio
                2009 Nissan Frontier
                1997 chaparral 180LE
                  torch is a beautiful thing
                    Yup a torch and a heavy duty hydraulic press does the trick ... I had the same problem . The steel sleeves rust on the the bolt and are fused to the bolt .
                    I ended up taking both to a machine shop to get them off ...
                    Hope you can have better luck with a torch and hammer ... but odds are you will have to get new bolts from pounding on them so hard .
                      The Suspension Install Begins Now !!!
                      Its about time for the install .... started on it last week and ran into a few issues . Some rust in the rear strut wells . It was to be excepted and I did fine some ... lucky enough that it was not to bad .. I was able to grind it away and clean it up .
                      Unfortunately the rear strut spring top hat were bad enough that I am not going to use them ... had to order up some new ones .. so thats been my delay now . I will have all the suspension buttoned up by this weekend .. so lots more pictures to follow .
                        When you install the new suspension, apply lots of grease between the strut hats and the body of the car where they mount. That should keep the rust from forming again.
                          that a great idea, i will do that to mine too.
                          2012 Kia rio
                            Well I epoxy primered, painted and then under coated the area before I installed the rear struts ... I am pretty sure this will do the job.
                            I dont plan on running it in the winter.
                            Its now going to be a fair weather car ..
                              Problem with paint is that it chips and cracks especially where the two surfaces mate. Grease is always pliable and will continue coating the area. In any case, Vancouver is mild in the winter and I am sure it will last.
                                same here thanks lex.
