And so it begins....323BG hatch ----> V6 powa with a few extra surprises
    it was nice meeting you dan good luck with the build cant wait to see how it turns out
    1st 323 - wrecked - RIP
    2nd 323 - stolen - RIP
    3rd 323 - daily driver
      Sure thing Paul - the Vegas weekend was a blast, the drive home, not so much - thanks for having everything ready to go, really saved me some good time.
      So far I got most of the ~25 dings done, it has some slight damage around the pass side keyhole, which I was going to shave, then I realized 'wait, that's the side I'm going to be going in through in the future' so I have to get the metal fixed
      The grand plan is to break it down as follows:
      *exterior - fix cosmetic body damage, shave 3rd brake light, 93+ tails & garnish, upper/lower rear spoilers, GTR rear bumper w/lip, GTX front bumper, side skirts, fender flares, and some 0 or very low offset 16x8 or 9s (which I have to find a way to get from Germany), then paint (silver metallic), EDM headlights & corners.
      *interior - recover dash & door panels, mx3 front seats, mx3 carpet, gas door & trunk release cables, all mx3 wiring harness, manual seatbelts, and if I get lucky a full sunroof.
      *engine bay - rhd conversion, engine bay cleanup (seam welding, smoothing/covering up all unused holes or fasteners), brand new mx3 OEM wiring harness (no more oily stiff crap), mild wire tuck, and of course the fully rebuilt KLDE with a fully rebuilt g-series (new synchros, bearings, CZT diff) with an Escort 5th gear for the nice freeway cruising. And something about a megasquirt and an M62. Fidanza flywheel/Clutchmasters clutch.
      *suspension - still thinking about D2 or k-sports, though I think I may get some koni inserts/eibachs for that price. Full mx3 subframes front & rear, 4-wheel disc brakes (no ABS), and hopefully a bunch of Superpro bushings.
      That's about it, the plan is to have it run mid 14s on the motor and high 12s on boost (7lb, non-intercooled, stealth install). Definitely don't want the fastest or flashiest car (hence why I'm skipping the Lamborghini orange pearl paint job I initially wanted and sticking with a n elegant silver), but it'll be the way *I* want it, which is really all one can ask for.
      Should take me most of the summer, I'm definitely excited about the challenge and looking forward to doing some good work.
        Wow a supercharged V6 powered 323!! Did you source a PGT or MX-6 SC kit?? Or are you going to put your fabricator hat on for the brackets and source a Grand Prix charger from the wreckers??
          Found one already made, but I'll probably have to customize it to my liking. It's an A/C location mount clutched M62, which means I can turn it off with a switch. The 7psi will be achieved via an overdrive crank pulley. If I do it right, it should not even be obvious that it's boosted and the intake pipe will look like a cold air intake.
            Kool! Mad Max's Supercharger also had a switch. LOL
              Where is Neuman with his quote when you need him.
              This is my BP. There are many like it but this one is mine. My BP is my best friend. It is my life. I must master it as I must master my life. Without me, my BP is useless. Without my BP I am useless. I must drive my BP true. I must drive straighter than my enemy, who is trying to beat me. I must beat him before he beats me.
                Picked up the supercharger kit today, it's in great shape. The M62 is freshly rebuilt, there is only one bracket holding it very securely to the block, and it uses all OEM tensioners - as stealth as I wanted it and more. Even came with good black silicone couplers and t-clamps. The clutched pulley works great, this will be my favorite 'push to pass' button yet
                7 more days till I officially kick this project in gear!
                  very very cool
                    It looks to be a great begining to an epic BG
                      Pictures!
                        haha nice man!!! pics! and get this bracket re-fabbed for other people
                          I should, and charge like $149.99 for them - it's actually just a 3/16" plate with a few choice holes drilled in it.
                          Here's how you do it.
                          1) Remove A/C compressor from your KL
                          2) Take 3/16" steel plate and bolt onto a/c bracket
                          3) Take blower and bolt to 3/16" plate
                          That's it. Sure you, have to mock it up a bit to make sure the pulleys line up, but that's really the hardest part.
                          Yes, there are other fitment issues - I'll relocate the oil filter housing, and probably rebuild the lower radiator support to make a little more room and make it comfortable to work there. Pics and all that jazz will come next week when I'm done with finals.
                            you should at least take some measurements and such then you can sell/help out other KL swapped BG people who want more power
                            because im getting sick of my GE chassis haha.
                              wow a supercharger for your v6. thats boss
                                Originally posted by superscort93 View Post
                                Pictures!
