klze swap
    Did a little work today, started tearing aparts the parts car and also got a little done on the protege
      sweet man id spray mine again but i need a reg on my compressor last time i shot primer at 120 psi .
        holy crap 120, man that must have benn fun lol
          lookin good man! i can't wait to find another BG to have fun with!
            here is a few shots of the pro, she seen some sunlight yesterday for the first time since god knows when, oh and a pic of the mx-3 almost at its end lol.
              please if you have that pop up glass roof piece from the MX3 save it & get me the dimensions of it. mine busted & that looks pretty close
                that i dont have, i dont know if they are any different than the pro glass roof or not. if they are the same i can give you a measurement. the mx-3 i have had an aftermarket sunroof
                  oh and the glass broke on my today when it was placed on the floor, lol you couldnt have asked me this before
                    didn't know. either way, please take a picture of how it was mounted in. the front tabs & the rear tabs, theres a huge chance they have the same mounting. (which i need as well as the glass panel) i need something bad tho. the only car can't be driven in the rain.... that sucks
                    If you still have all the mounting bits ( even if the glass is broke..... please please please pic me & save them)
                      all i could save was the mounting clips from the front of the glass and the rear clip. the actual glass and frame were completly shot. nothing salvageable. you had to catch me a day late after everything is cut and squashed. i will take some pics of the clips for you to see if there is anything there that you can use.
                          did some more work on the car today, repaired my cheap wooden engine stand for the kl, much easier to move around until it installed. prepping the engine bay for the v6, pass side mount, swapping over the power steering lines and keeping the a/c intact. tomorrow i will fiddle some more with it. maybe even test fit it in the bay.
                            would be better with some pics lol. here they are. here is a pic with my new headers which are going to get sent out this week i hope for ceramic coating.
                              well got some more work done today, installed the mx-3 lcas, rack and pinion, mx-3 sway bar, cleaned and painted the power steering lines, and test fit the kl in the bay to see where i stand in the cooling department. a/c compressor needs to be replaced with a v6 one and also a couple of lines. the protege a/c lines can work with a little tweaking but the compressor has a different bolt up pattern. anyways some time this week the kl is coming out again so i can paint the engine bay, then in she goes for good.
                                well guys, a little update. the engine bay is taking longer than i expected due to work but i did manage to pick up a very fresh looking a/c compressor and the lines from an mx-3 v6, they look almost identical to the pro comp but like i posted above the bolt pattern to the a/c bracket is slightly different. upon closer review i might have to tweak the pro line that goes from the comp to the condensor. i just dont see how the mx-3 line will work without doing anything major. i bent that line carefully while it was bolted to the compressor and i think its going to work. will have to post up some pics
