klze swap
    looks nice! what harness are you using?
      Lookin' great! Jones-in' to see what rad you end up usin'
        Must feel good to have an almost running protege finally eh? .
          nice man! looking real clean!
            Using a harness from a 94 gs v6, I switched the location of a white wire with a red stripe that goes nowhere in the mx-3 fusebox to a black and red wire that goes nowhere in the pro fusebox but somewhere in the mx-3 fusebox. got most of the stuff powered in the car but still no spark. doesnt help when i get home late and i have no diagrams or multimeters to check.
              it would feel better if it was running. then i can enjoy a few brew
                well got fuel and I know th einjectors spray because the spark plugs are wet. got power to the dizzy but no spark. possibly dizz gone bad but I dont have another one to test with.
                  check the resistance for both coils, if you need specs let me know. also i can show you how to build the HEI module, its fairly easy.
                    indeed i do need specs
                      ok sounds good man, would you just rather me send you the HEI harness and module? i have a spare one laying around and i'd only cost me around $7 to fab the harness...you'd just have to mount/ground it off. it's real easy...you just need to order the power tower...i can show you how to mod it.
                        how much do you want for that? any info that can help would be sweet
                          When contiplating doing the v6 swap I did tons of research and found that the distys on the v6 suck ass. Here's a link on how to do that mod.
                            well guys after spending some time sorting through wires here and wires there thinking i did something wrong, i decided to get two fuse boxes and amalgamate them together. protege box has some extra stuff and matches better to the harness going into the car. anyways pic time
                            last pic is the finished product that i will install.
                              Got a new dizzy today and installed it and decided to make a like vid
                              v6 protege gt with a lot of things not hooked up, just to see if it starts.
                                wow glad to see its running, sorry about not getting you those specs! works been crazy...
                                is it running on all 6cyls? It's kind of hard to tell lol
                                Haven't figured out a rad system yet?
