G-Series Differential Services
    On some inspection i have seen that the gear on the diff is likely the same for all G series trannies.
    I have compared a PGT, MX-3, MX-6 and looking down the hole at the diff speedo gear i can count 4 rows of teeth across in all 3 trannies. When it comes to the speed sensor is as follows: PGT 20T (pink longer depth gear), MX-3 21T (White short), MX-6 21T (white short)
    If others have any input, feel free to add to this.
      the speedo gears them selves have different ratios in some cases. find the one that reflects to your use.
      the speedo ring is the same across all G series transmissions.
        Jon, are you still offering these services?
          If Jon's not doing it anymore, I can still do it.
          --Ferdi
            Thanks for the info!
            Now i have pulled the speedo gear from a scrap trans, now i gotta carefully pull the diff bearing of the Mfactory diff and reinstall it.
