KIA Head & Piston ??????
    Alright, now I have been looking around these forums and can't find this ?
    What would the benefit be if any, Pistons and head swap would be on an EGT? Would it benefit me perforance wise?
    91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
    95 Probe SE- Sold!
    95 Escort Pony- N-1 coilovers, Weapon R CAI, clear corners, and Corksport tower strut bar, Lowtek struts, Moog swaybar endlinks, custom cat-back exhaust, tinted taillights, EGT side skirts, EGT front and rear bumpers, custom short shifter, clear side markers,
    custom painted and dyed interior, MX-3 seats F&B, MX-3 center armrest. some day BP swap.
    91 EGT- Eibach springs, Pacesetter header, custom 2.5 " catback to a Megan Racing muffler, 17" Motegi wheels and K&N cone filter.
    The rest is bone stock.
    doubt it
    http://www.wihandyman.com/forum/showthread.php?t=47653
    my fs thread
      no
        you would possibly gain a slightly more aggressive set of cams or cams with a little less overlap with stock cam timing (hear-say). Not exactly sure what the differences in the profiles are but it's something worth looking into if you're all about budget upgrades. I would be curious to know.
        Last edited by Georonimo; 07-22-2009, 11:24 AM. Reason: getting the facts straight!
        http://videos.streetfire.net/video/M...-run_18851.htm
          Wait, solid lifters? More info!
            no solid lifters, their all hydraulic till 99 on any BP.
            kia cams= 2nd gen cams= 1st gen cams
              ok just what I thought...
                I actually stole hla's from a 97 becuase they "supposedly" don't deflate like the 1st gens
                  Thanx for the get backs! I appreciate it. Was offered a Sephia head and pistons, and also Miata head and pistons. I knew about the positives of the Miata but not the Sephia.
                  Thanx again!!!!
                  95 Probe SE- Sold!
                    What year Miata?
                      Not sure what year. Already off car. Says BP05 on side of it. Just like the EGT's.
                      95 Probe SE- Sold!
                        I have a turbo kit for sale that i had on my 1996 dohc sephia. Its all custom but not getto rigged. its a hybrid dsm/kia turbo manifold that i had designed at a performance shop here in vegas.
                        THE TURBO SEPHIA
                        http://video.google.com/videoplay?do...URBO+KIA&hl=en
                          How much?
                          95 Probe SE- Sold!
                            Originally posted by scort4life View Post
                            How much?
                            - MODIFIED CUSTOM TURBO EXHUAST MANIFOLD. WELDED BY PROFESSIONAL FABRICATION SHOP
                            - DSM BIG 16G TURBO
                            - 320CC INJECTORS
                            - CUSTOM MADE WELDED BOOST PIPES, FOR NO BOOST LEAKS.
                            - TOP MOUNT INTERCOOLER
                            - AUTO-METER BOOST GAUGE
                            - VACUUM LINE WITH T-CONNECTION FOR BOOST GAUGE
                            - B.O.V. AND THE BLUE BOOST HOSE TO THE IDLE CONTROL VALVE
                            - MODIFIED WATER NECK HOUSING (SO THE DOWN PIPE HEAT WON'T MELT THE RUBBER RADIATOR HOSE)
                            - O2 SENSOR FITTED INTO THE O2 HOUSING
                            500.00 shipped
                            THE TURBO SEPHIA
                              Originally posted by ebay listing
                              Will fit 1.6 and 1.8
                              1.8 block is longer so the manifolrd will NOT fit the 1.6. So is the kit for the 1.6 or 1.8?
