There are 2 Sportage with FE3s at the local JY. Anyone interested in one of these engines? I might pull one out for myself.
Kia FE3 anyone?
Originally posted by mx-3_4evr View PostWait a minute, is it an interference engine?GRIPtoLIVE........................................ .........
NA6C new track slut-NB8C waiting on parts
94 E36- RB20 swap -sold
93 323 budget track slut RIP
FEARLESS MOTORING..........................................
there nto really worth it. you need so many parts from a imported fwd fe3 to install it in a fwd app, that after you spend the money for the extra parts, you would have been better off just buying the real fe3.
the kia's only use is to use parts off it. grab the head, and toss that up. bet someone would be intrested in that at least.~PaTricK~
-Current car's-
What are you driving?
if my truck didnt suck so bad it would be pretty neat to build an FE3 powered rangerEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Pull the heads as pat said. heads with cams in them. they are not interference. & you could easily swap the motor into your MX3---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
wrong. im not sure what thats for. im thinking its the fan. that bit tho is easy to mistake for the waterpump. the waterpump is timing belt driven.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
yes. f2/f2t works & the coolant u got right!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
going FE3 now?-Jack
