Toyota E153 transmission swap
    Have you looked at using the bg carrier bearing support on the toyota bearing and shaft ?
      not yet because i don't have the adapter plate yet. it all is going to depend on how everything exactly lines up...
        Yeah the G series hydrolic transmission is shoe horned in my car, so the 153 if it is any bigger, especially LONGER will NOT fit in my car, and I have the frame rail notched already.
        Still going to be a good read, especially if we ever want to put the engine in the back of my car ;-P
          the custom clutch setup arrived in the mail today. everything seems to fit together perfectly, but unfortunately one of the clutch pucks was cracked in shipping. shouldn't take long to have another made up.
          pics:
          pretty straightforward concept here... 1800 pound high-clamp pressure plate to fit the stock BP flywheel, 225x150mm disc with a toyota splined center hub. the pressure plate isn't "special", i could use any BP pressure plate... the disc is the custom piece.
            nice i need to get my tig welder so i can do a swap like this
            ________
            LovelyWendie
            1995 escort wagon gtr/holset
            1993 323(sold)
              i might be selling kits eventually but they would be for FWD. the clutch, adapter plate, upper mount, and some other parts would work for AWD though
                i might just try to get a fwd car eventually they are much easier to work with
                ________
                Expert Insurance
                1993 323(sold)
                  i have a green escort GT that i'm trying to sell, cut you a good deal on it if i can keep the motor
                    im good then i would have 3 non driving cars and one i cant drive in the rain
                    ________
                    Vapir Oxygen
                    1993 323(sold)
                      more delays...
                      Apparently the drawing that TurboTim on miataturbo made with his faro arm a few months ago is too far off to use. The machinist making the adapter plate cut a test piece on his CNC based on that pattern, and the crank centerline was off by 0.073". The bolt pattern on the oil pan section of the bellhousing is also slightly different between FWD/AWD and RWD, which i didnt realize.
                      Anyway, he had his BP pattern scanned on a CMM table locally, and using that new pattern made up a sample adapter... close but no cigar, the crank centerline was still off by 0.010". He is making some final adjustments and should be finished soon. :D
                        Sounds like you should have this thing ready by next year!
                          sounds expensive lol
                            adapter plate prototype is finished! shouldn't be long now folks... almost time to start fabricating
                              wow! very impressive! looking forward to seeing the progress.
                                wow man. when this is finished you need to offer a complete swap for this! This would be a sweet kit to sell!
                                Daily Driver--'07 Traitor Corolla--Traded for a '11 Chevy Cruze--Traded for a '12 Dodge Charger
                                Project Car - looking for a clean AWD Protege, or maybe a monster Miata donor
