Toyota E153 transmission swap
    the guys in nz were adding 10mm spaceres to the TOB to make them work
    ________
    EASY VAPE VAPORIZER TEMPERATURE
    1995 escort wagon gtr/holset
    1993 323(sold)
      some people have done that while others supposedly didnt do anything at all, i'm going to see how it pans out. they did 10mm because the plate is 10mm (3/8 plate) thick, but if the mazda fly/clutch assembly is thicker than the 3S setup then it may not actually be needed
        good call let me know how it pans out. oh does your trans have a pilot bearing?
        ________
        Concept X6 Activehybrid
        1993 323(sold)
          nope the E series doesnt use a pilot bearing. luckily the pilot bearing hole in the BP flywheel is large enough to fit over the huge input shaft
            thats what i thought but i wasnt sure if it was just the AWD boxes or not
            ________
            Coach purses
            1993 323(sold)
              Thank you for taking the initiative to start this driveline swap. Like the guys in New Zealand who offer a Celica GT4 conversion kit for the BG GTX/GTR, you'd be in a good position to offer a conversion kit or at least the adapter plate to make some coin to offset the R/D costs. As you can already see by the amount of people subscribing, you'd have a good lineup of people willing to perform the same swap if all goes well. Keep up the great work![/QUOTE]
              Yah.. you know those NZ guys with their kits? That's where this orig. adapter plate came from. The one that sucks and had to be redone. Tim Taylor is making these new ones so that they don't suck, but the fact that that NZ plate was so far off makes me question everything else about their "kit". Jon and I both should be getting our adapter plates soon, and when mine arrives along with my modded oilpan, I'll start a build thread for the AWD crowd.
              My gearbox is (finally) done and in my garage. It started out as a pair of deaders, one with a bad xfercase and the other with dead synchros or somesuch. A machinist wizard who used to build gearboxes for the factory rally team when they ran Paris-Dakar took 'em apart, combined stuff, and used lotsa very hard to find new guts to put it together as a RC185 close ratio spec but with the ST205 shorter final drive. He's so confident that it can handle more than 400ftlbs day in and day out he's warranting the damn thing. All I know is having seen the internals of this box, it's so much stronger than the POS BPT box it just ain't funny. For instance the centerdiff ring and pinion are bigger than the ring and pinion in our rear diffs, all bearings are in steel plates instead of pockets in the alum. case, it's pressure lubricated, man oh man Toyota didn't screw around. We looked at the rav4 thing but I hate locker centerdiffs on dirt, been there done that. And it's enough weaker than the alltrac box to justify not going through the hell of installing it; custom mounts, modding an alltrac propshaft, and who knows whatall else but at least the toyota halfshafts will talk to gtr hubs without mods. We're gonna miss Wild West but maybe just maybe we'll have it all together in time for Mt. Hood the end of October, maybe...
              Just BTW ol' Mr. Taylor is underwater on this project and I bet he wouldn't mind at all trying to get some of his investment back if some of y'all wanted to have him make a few more non-sucky adapter plates!
              And oh yeah Jon, can you gimme details on that clutch? Looks like just the thing!
                that was my hope for doing a kit... i'd reproduce the mount kits, and Tim could make the adapter plates.
                the one he tried to copy from was actually one of the kits from Sweden, i dont think anyone in the states has managed to get their hands on a kit from NZ yet. Tim seems pretty skeptical of their quality too, though
                  NZ, Sweden, hellwithit, Buy Local!
                  I'm starting to get twitchy, thinkin rallying a car that's, you know, reliable...
                    After talking to my New Zealand contact for all my parts, all I can say is that I would be HIGHLY suspect to any Kiwi-engineering.
                    I hear most of their engineering is done with the ol' No.8 fence wire and nippers.
                      i want an to do an awd swap so bad
                      ________
                      Da buddha vaporizer
                      1993 323(sold)
                        it coming along great, im very intrested in this and if jay make a progrees post for the awd pros we will be set.
                        5 boosted bp cars,why...
                          Jon you are a pioneer. I'm following closely with the progress. I hope your investment in this project pays off for you and everyone who shares an interest in this mod. I myself am interested in the double synchroed trans. Did any year of either of the two applicable transmissions come factory with a reliable lsd? Is the adapter plate made from steel or billet aluminum? Do you expect having to modify the engine bay to accomodate the trans or does it squeeze in there?
                            the only trans of this type that came with an LSD was the 93+ MR2 turbo. it was a weak viscous type lsd. theres several aftermarket options including Quaife, Kaaz, and TRD.
                            the adapter plate is steel. not sure yet, hopefully nothing too drastic!
                              im surprised @ how much progress i've missed so far. Thank you jon for putting this together.
                                well not that much progress really lol. just collecting parts and waiting for the adapter plate to be done...
