I can fix your rims....
    I'm a alloy repair shop in wilmington De. We offer a long line of services ....
    1. Straightening
    2. Welding
    3. CNC Face Machining
    4. Refinishing Powder Coating
    5. Chrome Plating Service
    6. Custom Work
    And we offer much more call for more details and Prices.....
    Viking Wheel Service
    3901 N. Market ST.
    Wilmington, DE 19802
    302-764-4041
    302-602-5551
    fax-302-764-4042
    E-mail- caddy142db@aol.com
    check us out at http://www.vikingwheel.com
    Let me know your from the forum and get $15.00 off any order over $150.00
    So if you hit that pot hole or curb give us a call you will be glad you did...
    __________________
    Honda
    can you widen wheels??
      Yes we do widen wheels as well...
      Honda
        too bad your in the states .. my work sees lots of damaged wheels . especially logging trucks. 22.5's n 24.5's
          can you do vacuum metalizing on plastic hubcaps?
          http://videos.streetfire.net/video/M...-run_18851.htm
            Sorry we don't do much with hubcaps.....
            Honda
              I have a set of alloy rims that I hit a pothole and took a chunk of tire and rim. How much do you charge to fix the rim?
                Glad to see someone local , I have a 19" chrome rim with a 4-5" crack on the outer lip what would be a rough estimate on repairing it. maybe I should have looked at the date first
                  Dude the post is 2 years old. Why dont you try calling that number on monday and checking if the company is still around
                  1994 Escort LX Wagon
                  2013 Hyundai Veloster Turbo
                  91 EGT - Junked May 2012
                    already checked and yes they are still in business
                      i wish u were closer
