my protege build.
    Got this for free for parting a wrecked miata for a friend. was alot of work but worth it.
    The head is going on my bp build for next summer, not sure yet what ill do with the rest of it lol.
    DX BP swap/turbo build
      VERY nice! I'm looking forward to see what someone can do with one.
      -Steve
      94' Protege < Worklog<SOLD!
      VF10 powered!
      262 Whp & 257 Wtq
      13.1@107
      '02 Suzuki Bandit 600s
        excellent!!
          for free???? ****ing awesome! gotta go MS and get the VVT working!
            ^ theres no VVT on that motor. its just a normal BP4W head
              Like Ryan said, no vvt.
              Tho I did work my ass of pulling tons of parts for this guy off the miata, plus this engine/trans for myself, I guess it depends on how you look at free lol.
                Whats better about that head than a BP05 head?
                1992 MX-3 GS - KLZE
                1997 Probe GT
                Its not a BP05.... Its a BPOS... BIG PIECE OF ****
                  they have solid lifters and they flow more than the bp-05
                    Sweet! Almost like the KLG4 of the KL world..
                    1992 MX-3 GS - KLZE
                    1997 Probe GT
                      What is your wastegate setting at? Also, what wastegate did you use for the hybrid? Any fabbing necessary?
                        I use a vf10 wastegate actuator. I had to drill new holes in the wastegate mount to mate up to the compressor housing with the way I had the housing clocked. I have a Perrin mbc, boost set @ 15psi.
                          I had the same question until you posted this. Now it's in my language. lol
                          '88 323 sedan, K-swapped..
                            Its supposed to be the angle of the intake ports that makes its flow better.
                            "Who Dey"
                              Found a modified, rebuilt and balanced 0-mile tbird turbo for cheap. Its been upgraded with a 16t wheel. Compressor housing and center has been machined to fit. Wheel size is ~ a mm smaller at the inducer than a vf12 at 43.4/56. The stock tbird (which Im running now) compressor wheel is 39/52.5. Not an extreme upgrade, but I made 212whp@13psi and ran 13.5@107 on 15psi on my current tbird turbo. I think thats "respectable" for what I have in the car as it is. So I snatched it up to see what it'll do..
                              I plan to use a vj11 turbine housing for the "bigger" A/R, on a gtx manifold modded for an external gate. Ill have to modify my cs downpipe for the ewg and also swap the flange for a vj11 flange. Luckily I have a few vj11 housings and a stainless vj11 flange just hanging around lol..
                              Either way, it sure is purty.
ID:	1230316Click image for larger version
ID:	1230317Click image for larger version
                                if that compressor housing had a steeper taper it would net significantly smoother flow transition across the blades.
                                Either way. your going to notice a serious step up from the T-bird. Your cold side inlet will prove the most important part.... fit a 2.5" AL intake pipe to a flange & taper that entrance more- port match the flange/pipe & enjoy.
                                your going to love it. how soon are you installing it tho??
