Check engine light came on
    Hello all,
    I recently bought a 1998 Protege 1.5 and it runs just fine. The only thing I did was increase the idle slightly. The car idles better but the check engine light came on. Garages around here want anywhere from 75 to 100 bucks to hook up the code reader. I did a site search but couldn't get anything that applied. Any ideas?
    thx,
    baz
    For that much money you could buy a code reader .
    98 protege lx 1.8l
    short ram intake custom
    crane hi-6 ign.
    14 miata alloy wheels
    .50 over pistons and some other tricks .
    my protege
      one time i got quoted 40$ to check a code;
      and i thought that wuz expensive;
        Turns out the 'check engine' light was the gas cap. There's a relief valve button in the middle of the gas cap. I guess you have to press that every time you put fuel in the car. Soon as did that, the 'check engine' light went out. Then I read on the net that winter grade of gas has a higher sulfur content up here in Canuckleheadland and that sets off some fuel sensor or other.
          Also, if the light comes on again, you can bring it to an auto parts store, such as Advance Auto Parts or Autozone, and they should be able to read the codes for free. Not sure what parts stores are near you though, but I'd check there first before overpaying for a shop to do it.
            Code reader Site
            Go to AutoZone, Code Read's it's free, almost here in Tijuana, Mexico
            take care..
