Knock controller/sensor wiring question
    Where is a good place to ground the wires outlined in red to the EGT harness?
    I got the controller and sensor off of mx6.com..The shielded wire after the sensor connector was shot and so was the shielded wire going to the controller from being cut. Will it be fine without them being shielded or what should I do? Let me know
    That is simply a chassis ground. However the EGT never came with a stock knock sensor.
      I'm fully aware of the GT never having the knock sensor What dd you think I was putting it on a n/a bp? Years ago when I got my gtx front clip, I never took the gtx engine harness off or the knock controller, stupid me.. I decided recently to aquire one and wire it in for ****s and giggles after not having one for years. You can usually find me over at FEOA rather than here.
