MY race car is for sale!
The specs:
Body
Protege 2001 sedan
Roll cage 12 points
Fiberglass hood
hood pins! rear and front hood
Custom bumper with P5 cover(not installed as you will see in pics!)
Front subframe, Ford Probe with steering rack and tie-rods
Rear subframe, Protege Mazdaspeed with some mods
Fonctional headlights with black housing
Engine
V6 2.5L
KL-ZE KL31, stock heads and block
Custom intake manifold
75mm Throttle body
Custom fuel rails
24lbs/hr Accel injectors
Aeromotive fuel pressure regulator
External Ignition coil Jacobs C-4
Megasquirt stand-alone ecu
Custom power-steering delete pulley
"front mounted" Jeep Cherokee 4.0L radiator w/ 2 push fans
Moroso oil accumulator
A lot of other Morose containers and devices!
B&M engine oil cooler
And a lot more!
Transmission
4.33 final ratio(MX3, Probe), welded differential(great for drag, but awful on road circuit)
Protege Mazdaspeed drive-shafts.
Custom Short shifter, high reach
Clutch Centerforce Dual Friction
Flywheel 13 lbs
Suspension
AWR Coil-overs, coils Eibach 400lbs/in fr, 600lbs/in rr
AWR top plates, adjustable
AWR adjustable rear lateral arms
AWR rear trailing arms
AWR rear sway bar 21.5mm, adjustable
AWR Link kits all around
AWR front strut bar
27mm front sway bar wit urethane bushings
Brakes
Protege Mazdaspeed Front
Mazda 6 03-05 Rear
Many brake pads available
Russell Stainless steel brake lines
Mazda 929 brake master cylinder
Exhaust
Akmost totally custom
Modded Pacesetter Headers
Resonator Thrust
Muffler Supertrapp
Wideband Bung
Interior
Dash is from the origina Protege, but it's been heavily trim down
Autometer 5'' Tach
Stewart-Warner gauges; oil temp, oil pressure, water temps, voltmeter
Switch board Moroso with fuses and Start button
6 points OMP harness
Braille Battery relocated to the rear
Kill switch
etc. etc.
+ lot of spare parts!
There is a bunch of small details to fix to be perfect to hit the track. The car is functional as we speak.
No seats, no steering wheel (possibility of one. but not sure yet) and comes on steel rims with cheap tires for towing it around.
Comes with a tow dolly!
Car is plated as a Off-road vehicle
Price...
8500$ very motivated seller!
You can e-mailme at: domspun@gmail.com
Pics:
Vids:
Video tour by a friend: :mrgreen:
The specs:
Body
Protege 2001 sedan
Roll cage 12 points
Fiberglass hood
Engine
V6 2.5L
75mm Throttle body
Custom fuel rails
And a lot more!
Transmission
Flywheel 13 lbs
Suspension
AWR front strut bar
Brakes
Mazda 6 03-05 Rear
Exhaust
Resonator Thrust
Muffler Supertrapp
Wideband Bung
Interior
Autometer 5'' Tach
Kill switch
etc. etc.
Price...
Pics:
Vids:
