Camera sucks as usual and makes everything look bad but here we have it
Two go in and one comes out (Operation body swap)
wish we could of metup when i was down in the area :/---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
yep stupid ****ing fuel pump relay... On a side note, after 4 relays quit working I found some wiring problems that the previous owner had hacked up when installing the car alarm and left them exposed It hasn't happened again since I fixed the harness running below the upper dash.
Originally posted by bomdoutscort View Postask drew hall how well it looks after a couple of months.1993 Ford Escort GT-T
1992 Mazda Mx3 GS((Parting Out))
1994 Honda Integra LsVtec-Sold
1984 Toyota Corolla SR5-Sold
1983 Ford Ranger-Sold
My Turbo Escort GT build thread
My HUGE f/s thread. Go buy!!!
Myspace yooo
the carpet, after it was dyed...c'mon man! even i knew that lol-Jack
awesome machine man. you inspire my own project to come.
i have a 93 Mercury Tracer and i wanna swap a protege into it xD
this beast is clean and all pretty, mine wont be so OCD tastic but im gonna clean it up a bit.Originally posted by atomicEGThaving the fastest/most powerful VJ20 is like wanting to **** the prettiest girl in the trailer park
sure you can do it, but most people aren't gonna be impressed
Certified:
CompTIA A+ | CompTIA Network+ | J-std
Updates coming soon... MOAR BOOST!!
Teaser, Goodbye vj20... Heeello T3! I just got done media blasting the gtx manifold back to nice and clean looking.
Starting to get pissed.. some of the parts that I'm waiting on still haven't showed up yet wanted to at least get most of this done before the weekend.
Got some of my needed parts in the mail finally
-4an to 10mm x 1.5 oil feed block adapter
-4an .065" oil feed flange
-4an 12" stainless steel oil feed line
1/2 npt oil drain flange (still waiting on the fitting for it)
2" to 2.5" coupler
M16x1.5mm Garrett banjo water fittings which I had to cut the ends off of and tap for 1/8 npt hose barb fittings so that the hose sizes matched the stock bp ones.
That's about it for now as I'm still waiting on more parts to show up.
oil & watercooled garrett??? specs?---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Garrett AiResearch TBO356 50 Trim .42 a/r cold, .48 a/r hot stage 1 turbine wheel, journal bearings. Only the turbine housing and wheel are from the TBO356. The CHRA I bought because the other T3 I was going to use didn't have water cooling. The compressor side is from my other T3.
gotta love the interchangeability lol, what do you think you'll put down for numbers with that turbo? stage 1 turbine wheel is how big compared to the stock one?-Jack
