Two go in and one comes out (Operation body swap)
    So, next week I think I'll be purchasing a new Precision 5431e CEA .60/.48or.63 which is good for 500hp.. In the mean time, I'm making another GTX manifold monstrosity for it. Not much to look at yet, soon enough though.. Still needs drilled for EWG and then a good cleaning before welding it up. Time to eliminate the adapter plate and the problems it's been giving me with oil drainage. It was either skimp on my turbo (chinacharger) and build my manifold, or, get a nice turbo and wait a lil longer to build my mani.. Budget won't allow both to happen so quickly.
      I like where this is going lol. F2T people do this all the time, so why not bp26.
        This new snail should be showing up real soon in the mail
        • CEA 54mm inducer billet compressor wheel
        • "E" compressor housing 3.0" inlet/2.0" outlet
        .60 A/R
        • T31, 76 trim stage III turbine wheel
        • Turbine housing, T3 .48 A/R with 5 bolt discharge (without wastegate hole)
        • 360° journal bearing system
        • 300-500hp
          Well, look what showed up this morning!!
          My old Garrett T3 50 trim vs the new Precision T3 50 trim,
          Sadly, it won't be here for long.. they gave me the wrong a/r turbine housing
            what A/R did they give you???
              the .63 a/r one
                still get all mushy inside seeing that turbo lol
                  I think I'll be starting a second build thread for this since this one has gotten fairly large and much has changed over the years. Thanks to everyone who has spent time looking through this thread! Look forward to the 2nd Chapter :D
                    post a link here to the 2nd chapter plz thx
                      Technically, it's more like the 3rd chapter if you include the other EGT shell into the mix lol
                        http://www.wihandyman.com/forum/show...le-Chapter-two..
